Installed from SCCM 9.0.3.  HKCU folders are present.  Created \PROFILE\.rapidminer.  Launch shortcut or .exe..nothing.  Launch as Admmistrator...nothing.  The only way it will work is if launching from an Administrator commans prompt.  No log files are create on all failures.  Users have Modify, Read, and execute (full) rights to the entire \program files\rapidminer.  Java 8 192 x86 & x64 is installed.
Running RapidMiner-Studio.bat does launch the program.
Ideas?
