Hi RM Staff,
First I hope everyone is doing well.
Secondly, I think there is an error of calculation in the
Extract Aggregates operator (
Time-series module) for the :
- median
- first quartile
- third quartile
It seems that these 3 functions are assimiled to the "minimum" function...
Here the results for the "Temperature" attribute of the "Golf" dataset :
These curious results allowed me to test the new function "percentile" of the
Aggregate operator. This operator give (from my point of view)
the good following results :
The process (use RM 9.1 (beta) to run this process) :
<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000-BETA2">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.1.000-BETA2" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.1.000-BETA2" expanded="true" height="68" name="Retrieve Golf" width="90" x="112" y="85">
<parameter key="repository_entry" value="//Samples/data/Golf"/>
<operator activated="true" class="time_series:extract_std_descriptive_features" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Extract Aggregates" width="90" x="380" y="85">
<parameter key="attribute" value="Temperature"/>
<parameter key="value_type" value="numeric"/>
<parameter key="except_value_type" value="real"/>
<parameter key="block_type" value="value_series"/>
<parameter key="except_block_type" value="value_series_end"/>
<parameter key="add_time_series_name" value="false"/>
<parameter key="sum" value="true"/>
<parameter key="mean" value="true"/>
<parameter key="geometric_mean" value="true"/>
<parameter key="first_quartile" value="true"/>
<parameter key="median" value="true"/>
<parameter key="third_quartile" value="true"/>
<parameter key="min" value="true"/>
<parameter key="max" value="true"/>
<parameter key="std_deviation" value="true"/>
<parameter key="kurtosis" value="true"/>
<parameter key="skewness" value="true"/>
<parameter key="ignore_invalid_values" value="false"/>
<operator activated="true" class="aggregate" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Aggregate" width="90" x="581" y="136">
<parameter key="use_default_aggregation" value="false"/>
<parameter key="attribute_filter_type" value="all"/>
<parameter key="attribute" value=""/>
<parameter key="default_aggregation_function" value="average"/>
<parameter key="Temperature" value="median"/>
<parameter key="Temperature" value="percentile (25)"/>
<parameter key="Temperature" value="percentile (75)"/>
<parameter key="Temperature" value="average"/>
<parameter key="Temperature" value="minimum"/>
</list>
<parameter key="group_by_attributes" value=""/>
<parameter key="count_all_combinations" value="false"/>
<parameter key="only_distinct" value="false"/>
<parameter key="ignore_missings" value="true"/>
<connect from_op="Retrieve Golf" from_port="output" to_op="Extract Aggregates" to_port="example set"/>
<connect from_op="Extract Aggregates" from_port="features" to_port="result 1"/>
<connect from_op="Extract Aggregates" from_port="original" to_op="Aggregate" to_port="example set input"/>
<connect from_op="Aggregate" from_port="example set output" to_port="result 2"/>
</process>
</process>Regards,
Lionel
