Error code 1
Rj_Chin
When I tried to open Rapid Miner, it showed Error Code 1. It is related to Java Error. May I know is there any methods to solve it?
Errors
MartinLiebig
HI
@Rj_Chin
error code 1 is generally a failure without anything more. Can you check your launcher.log in $USER/.RapidMiner/ . This should provide more information.
Best,
Martin
komwut_u
I found error code 1 like attached file below.
How can i fix it ??
Thank you.
rapidminer_errorcode_1.txt
IngoRM
I am not 100% sure but I think I had this error before when I accidentally installed a 32 bit version of RapidMiner on a 64 bit system (or the other way round). Please make sure that you install the correct version of RapidMiner matching both your hardware and operating system.
Hope this helps,
Ingo
varunm1
Hi
@Rj_Chin
I faced this earlier as I installed different version of RM on my 64 bit machine. Also check your JDK, if possible try to reinstall both RM(32 or 64 based on your system) and JDK.
I am not sure if this is RM specific error cause I saw it with other softwares that run on java as well.
Thanks,
Varun
