Hello everybody,
I have only recently started working with RapidMiner and am quite new in the field of machine learning. For a project at my university I'm mainly concerned with the preprocessing of data.
At the moment I am asking myself if it is possible to link two tables so that one table can take "knowledge" from the other table. I don't want to join them. Afterwards I would like to have further two single tables. A concrete example: I add a large dataset (from now on called dataset 1) that contains numerous attributes and examples. Furthermore I add a table in which all available attributes which are shown in the dataset 1 are listed (from now on called process value table). For the analysis of a certain question (from now on called analyse 1), however, I usually only need a small number of the given attributes. In the process value table the rows contain all attributes from dataset 1 and there is a column called "Required for analysis 1". If the value of this column is set to "Yes" for an attribute, then this attribute is needed for "Analysis 1". Now I would like to build my model so that I can say: All attributes where the word "Yes" is written in the column "Required for analysis 1" of the process value table should be selected from data set 1 and played back in order to start the analysis with the selected data afterwards.
I tried do showed it better with some pics, but I can't upload picture at the moment. I have to spend more time here, the system says
Does anyone have an idea how to implement this in RapidMiner? Maybe about some detours, transforming the process value table or something else?
I would be very grateful if someone can help me.
Many thanks in advance
Best regards
Moritz
