Hi @rtrivedi,
I'm not specialist of medecine, so I went to Internet to understand what is ICD 9 classification.
If I good understand ICD 9 is an expression like abc.d (for example 123.5) or abc.de (for example 425.23) where a,b,c,d,e are numbers, to define a disease, right ?
In this case I propose the following process :
<?xml version="1.0" encoding="UTF-8"?><process version="9.0.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.0.003" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="text:process_document_from_file" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Files" width="90" x="179" y="85"> <list key="text_directories"> <parameter key="ID9" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\Tests_Rapidminer\Extract_informations"/> </list> <parameter key="file_pattern" value="*.pdf"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="179" y="34"> <parameter key="mode" value="regular expression"/> <parameter key="expression" value="[ ]"/> </operator> <operator activated="false" class="text:extract_information" compatibility="8.1.000" expanded="true" height="68" name="Extract Information" width="90" x="380" y="34"> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"> <parameter key="IDx" value="/\[[0-9]+\]/"/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> <list key="jsonpath_queries"/> </operator> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="select_attributes" compatibility="9.0.003" expanded="true" height="82" name="Select Attributes" width="90" x="380" y="85"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value=".*\..*"/> </operator> <connect from_op="Process Documents from Files" from_port="example set" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
To execute this process, you have to :
- Set the path where your text file is stored in the parameters of Process Documents from Files operator.
- Eventually set the file pattern in the parameters of Process Documents from Files operator.
Does this process answer to your need ?
If not, can you be more explicit about what you want to do ?
Lionel
Hi , Thank you looking into this , i have attached the data file below that has the ICD 10 codes, the use case i have is as follows, IF a user types Typhoid Fever, it will in turn return the ICD 10 Code , A04. I was planning on using this file to train my model and then use the input as Free Text to return the ICD 10 with a confidence interval.
Here is the link to the ICD-10 training file
https://drive.google.com/open?id=19Y8gn3qRNmIsJdYB1FupSTiXTIGm1pdS
We have been working on this topic too.
Perhaps you could try to specify more the use case you have.
Thank you for looking into this Sven,
