I'm running Market Basket Analysis in Radoop Nest. I retrieve my data from Hive. And since there's no FP-Growth and Create Asociation Rules in Radoop Operator, I run them in Spark RM but always finding this trouble:
Process failed abnormally
Ooops. Seems like you have found a bug. Please report it in our community at
https://community.rapidminer.com. Reason: ERROR : Ended Job = job_1531799644051_135092 with errors Message: Error while processing statement: FAILED: Execution Error, return code 2 from org.apache.hadoop.hive.ql.exec.mr.MapRedTask
eu.radoop.exception.NoStackTraceOperatorException: ERROR : Ended Job = job_1531799644051_135092 with errors Message: Error while processing statement: FAILED: Execution Error, return code 2 from org.apache.hadoop.hive.ql.exec.mr.MapRedTask at eu.radoop.RadoopTools.formattedOperatorException(RadoopTools.java:1665) at eu.radoop.datahandler.hive.HiveHandler.runScriptsOrQueriesKillableAction(HiveHandler.java:1548) at eu.radoop.datahandler.hive.HiveHandler.lambda$runScriptsOrQueriesKillable$5(HiveHandler.java:1250) at java.security.AccessController.doPrivileged(Native Method) at javax.security.auth.Subject.doAs(Subject.java:422) at org.apache.hadoop.security.UserGroupInformation.doAs(UserGroupInformation.java:1807) at eu.radoop.datahandler.hive.HiveHandler.runScriptsOrQueriesKillable(HiveHandler.java:1249) at eu.radoop.datahandler.hive.HiveHandler.runScriptsKillable(HiveHandler.java:1204) at eu.radoop.datahandler.hive.HiveHandler.runScriptKillable(HiveHandler.java:1130) at eu.radoop.datahandler.hive.HiveExampleTable.materializeInFileFormat(HiveExampleTable.java:383) at eu.radoop.datahandler.HadoopExampleSet.materializeInFileFormat(HadoopExampleSet.java:880) at eu.radoop.operator.meta.PushdownOperator.deliverOrMaterializeInputHes(PushdownOperator.java:617) at eu.radoop.operator.meta.PushdownOperator.doWork(PushdownOperator.java:236) at com.rapidminer.operator.Operator.execute(Operator.java:1004) at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77) at com.rapidminer.operator.ExecutionUnit$3.run(ExecutionUnit.java:812) at com.rapidminer.operator.ExecutionUnit$3.run(ExecutionUnit.java:807) at java.security.AccessController.doPrivileged(Native Method) at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:807) at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:428) at eu.radoop.RadoopNest.doWork(RadoopNest.java:662) at com.rapidminer.operator.Operator.execute(Operator.java:1004) at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77) at com.rapidminer.operator.ExecutionUnit$3.run(ExecutionUnit.java:812) at com.rapidminer.operator.ExecutionUnit$3.run(ExecutionUnit.java:807) at java.security.AccessController.doPrivileged(Native Method) at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:807) at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:428) at com.rapidminer.operator.Operator.execute(Operator.java:1004) at com.rapidminer.Process.execute(Process.java:1310) at com.rapidminer.Process.run(Process.java:1285) at com.rapidminer.Process.run(Process.java:1176) at com.rapidminer.Process.run(Process.java:1129) at com.rapidminer.Process.run(Process.java:1124) at com.rapidminer.Process.run(Process.java:1114) at com.rapidminer.execution.jobcontainer.execution.SimpleExecutor.executeProcess(SimpleExecutor.java:74) at com.rapidminer.execution.jobcontainer.EngineRunner.onApplicationEvent(EngineRunner.java:68) at com.rapidminer.execution.jobcontainer.EngineRunner.onApplicationEvent(EngineRunner.java:30) at org.springframework.context.event.SimpleApplicationEventMulticaster.invokeListener(SimpleApplicationEventMulticaster.java:167) at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:139) at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:393) at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:347) at org.springframework.boot.context.event.EventPublishingRunListener.finished(EventPublishingRunListener.java:101) at org.springframework.boot.SpringApplicationRunListeners.callFinishedListener(SpringApplicationRunListeners.java:79) at org.springframework.boot.SpringApplicationRunListeners.finished(SpringApplicationRunListeners.java:72) at org.springframework.boot.SpringApplication.run(SpringApplication.java:305) at com.rapidminer.execution.jobcontainer.Application.main(Application.java:43) Caused by: java.sql.SQLException: Error while processing statement: FAILED: Execution Error, return code 2 from org.apache.hadoop.hive.ql.exec.mr.MapRedTask at org.apache.hive.jdbc.HiveStatement.execute(HiveStatement.java:297) at eu.radoop.datahandler.hive.PooledStatement.execute(PooledStatement.java:365) at eu.radoop.datahandler.hive.ContainerStatementPool$ContainerStatement.execute(ContainerStatementPool.java:67) at eu.radoop.datahandler.hive.HiveHandler.runScriptsOrQueriesKillableAction(HiveHandler.java:1465) ... 45 more
which is I don't know what to do. Please help
