Hello! For some reason, when i press run to execute python, this popped up. May i know what's wrong?
please have a look at the documentation and the examples. You need to define a main function called rm_main(...) which needs to be called. It's all explained in the examples.
BR,
Martin
Thank you so much! I have one more question!
As far as I can see the result should be your csv file, as you basically do data in -> data out
If you want to use the print logic keep in mind that the behaviour might be a bit unexpected, as the python operator will write your print statements to the log file, but not to the output. The output will be a panda dataframe by default
