Detecting languages in a dataset of texts
User: "s242936"
New Altair Community Member
Updated by Jocelyn
Hi to everybody!
I'm Marco and I'm an engineering student.
I thank everyone in advance for the work of this community. Under the council of @sgenzer , I'm opening this thread  to allow people who will have the same problem in the future to have a correct answer.
I have to analyze a collection of .txt documents (about 4000) in differents languages, after a rapid cleaning of dataset (to delete records with the same content) i was going to detect languages to organize better my analysis:
-first i used rosette tool and it works partially,
-secondly i used aylien tool and it works well... BUT
there is the problem of limited (1000 elements/day) or expensive Api key that these tools need...
So i try to use the method of this thread https://community.rapidminer.com/t5/RapidMiner-Text-Analytics-Web/Detecting-written-text-language-in-text-mining-using/ta-p/44319 but probably because i have to study better rapidminer it doesn't work.
Here my actual small process (i used a sample only to be faster but after everything will work i need to analyze all the collection):aa.PNG
Here the "results":
Here the errors:
Here my XML:
<?xml version="1.0" encoding="UTF-8"?><process version="8.2.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.2.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="text:process_document_from_file" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Files" width="90" x="45" y="34">
<list key="text_directories">
<parameter key="Articles" value="C:\Users\MMA\Desktop\PubMed"/>
</list>
<parameter key="encoding" value="UTF-8"/>
<parameter key="create_word_vector" value="false"/>
<parameter key="keep_text" value="true"/>
<connect from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="remove_duplicates" compatibility="8.2.001" expanded="true" height="103" name="Remove Duplicates" width="90" x="246" y="34">
<parameter key="attribute" value="text"/>
<operator activated="false" class="text:data_to_documents" compatibility="8.1.000" expanded="true" height="68" name="Data to Documents" width="90" x="179" y="391">
<parameter key="select_attributes_and_weights" value="true"/>
<list key="specify_weights">
<parameter key="text" value="1.0"/>
</list>
<operator activated="false" class="text:process_documents" compatibility="8.1.000" expanded="true" height="82" name="Process Documents" width="90" x="380" y="391">
<operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="112" y="34"/>
<operator activated="true" class="text:transform_cases" compatibility="8.1.000" expanded="true" height="68" name="Transform Cases" width="90" x="246" y="34"/>
<operator activated="true" class="text:stem_snowball" compatibility="8.1.000" expanded="true" height="68" name="Stem (Snowball)" width="90" x="447" y="34"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="8.1.000" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="648" y="34"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Stem (Snowball)" to_port="document"/>
<connect from_op="Stem (Snowball)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/>
</process>
<operator activated="false" class="filter_examples" compatibility="8.2.001" expanded="true" height="103" name="Filter Examples" width="90" x="514" y="391">
<list key="filters_list">
<parameter key="filters_entry_key" value="language.eq.en"/>
</list>
<operator activated="true" class="sample" compatibility="8.2.001" expanded="true" height="82" name="Sample" width="90" x="380" y="34">
<parameter key="sample" value="relative"/>
<parameter key="sample_ratio" value="0.05"/>
<list key="sample_size_per_class"/>
<list key="sample_ratio_per_class"/>
<list key="sample_probability_per_class"/>
<operator activated="true" class="web:encode_urls" compatibility="7.3.000" expanded="true" height="82" name="Encode URLs" width="90" x="514" y="34">
<parameter key="url_attribute" value="text"/>
<operator activated="true" class="web:enrich_data_by_webservice" compatibility="7.3.000" expanded="true" height="68" name="Enrich Data by Webservice" width="90" x="648" y="34">
<parameter key="query_type" value="JsonPath"/>
<list key="string_machting_queries"/>
<list key="regular_expression_queries"/>
<list key="regular_region_queries"/>
<list key="xpath_queries"/>
<list key="namespaces"/>
<list key="index_queries"/>
<list key="jsonpath_queries">
<parameter key="language" value="$..language"/>
<parameter key="isReliable" value="$..isReliable"/>
<parameter key="confidence" value="$..confidence"/>
</list>
<parameter key="request_method" value="POST"/>
<parameter key="body" value="&lt;%text%&gt;"/>
<parameter key="url" value="https://ws.detectlanguage.com/0.2/detect?q=&amp;lt;%text%&amp;gt;&amp;amp;key=*********************************"/>
<list key="request_properties"/>
<connect from_op="Process Documents from Files" from_port="example set" to_op="Remove Duplicates" to_port="example set input"/>
<connect from_op="Remove Duplicates" from_port="example set output" to_op="Sample" to_port="example set input"/>
<connect from_op="Sample" from_port="example set output" to_op="Encode URLs" to_port="example set input"/>
<connect from_op="Encode URLs" from_port="example set output" to_op="Enrich Data by Webservice" to_port="Example Set"/>
<connect from_op="Enrich Data by Webservice" from_port="ExampleSet" to_port="result 1"/>
</process>
</process>
PS: i wrote ****************** on purpose in the line of apikey to don't show it so this isn't an error.
Probably I'm missing something of trivial but I trust in your help.
Thank you all again,
Marco.
1 - 1 of 11
    User: "lionelderkrikor"
    Accepted Answer
    @s242936,
    good new :
    The results you obtained with the first method (Enrich Data by Webservice operator) were weird.
    In deed, the Process Documents from Files operator don't produce the 'text' attribute (although the parameter keep text is checked) and thus the request to the webservice was empty and in fine the returned results were empty too and displayed as '?' by RapidMiner...
    Note : You can see in Marco's second screenshot (first post) that there isn't text attribute in the resulting exampleset...
    The method here is to use a Set Role operator to "reveal" this text attribute (set as "regular" in the operator) and it works :
    The process :
    <?xml version="1.0" encoding="UTF-8"?><process version="9.0.002">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="9.0.002" expanded="true" name="Process">
    <operator activated="true" class="text:process_document_from_file" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Files" width="90" x="112" y="34">
    <parameter key="test" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\Tests_Rapidminer\Detect_language"/>
    </list>
    <parameter key="file_pattern" value="*.txt"/>
    </process>
    <operator activated="true" class="set_role" compatibility="9.0.002" expanded="true" height="82" name="Set Role" width="90" x="313" y="34">
    <parameter key="attribute_name" value="text"/>
    <operator activated="true" class="web:encode_urls" compatibility="7.3.000" expanded="true" height="82" name="Encode URLs" width="90" x="581" y="34">
    <operator activated="true" class="web:enrich_data_by_webservice" compatibility="7.3.000" expanded="true" height="68" name="Enrich Data by Webservice" width="90" x="715" y="34">
    <list key="regular_expression_queries">
    <parameter key="foo" value=".*"/>
    </list>
    </list>
    <parameter key="url" value="http://ws.detectlanguage.com/0.2/detect?q=&amp;lt;%text%&amp;gt;&amp;amp;key=xxxxxxxxx"/>
    <parameter key="delay" value="10"/>
    <connect from_op="Process Documents from Files" from_port="example set" to_op="Set Role" to_port="example set input"/>
    <connect from_op="Set Role" from_port="example set output" to_op="Encode URLs" to_port="example set input"/>
    </process>
    </process>
    Lionel
