Hi, I have used a dataset to develop certain association rules (using the association rules operator). Now when I am using the "apply association" operator, (with the same dataset as input for the Example Set) I am unable to understand the chart that is displayed in the output. It is showing a scatter plot and on hovering over each plotted point it is showing details like (Buying Napkins, 0.051, 0.981). This is for a specific point, the values as in "Buying Napkins" and the other two numbers are different for the different plotted points. I understand here "Buying Napkins" is the rule but I am unable to understand what the next two numbers (0.051, 0.981) mean.
