acuRun.bat not working on HyperWorks CFD 2022 student license/version
Hello, after installing the student version and select acuRun.bat in the run section, a notification jumps saying versions betwing acusolve and hyperworks don't match, and with that can't run acuSolve.
I have hyperworks cfd 2022 version and acuSolve 2022.3 version of student edition. (Those are the ones I got provided by the student license)
Someone has a solution?
Thank you.
You should be OK with an older version of the GUI and a newer versions of the solver. (The other way might give you issues.) If you just click 'Yes' on the pop-up to proceed, are you able to start the solver job?
0 -
Just runs the mesh calculations but acuSolve doesn't work, it doesn't start.
As you say, version of the acusove is 2022.3 and it asks me to have one above 2022.0. It feels like hyperworks is reading another version of the solver when it's shouldn't.
0 -
Can you attach the .Log file for that job that actually started (got past the submit panel at least)?
