Looping Clusters and store them in Repository
User: "flo"
New Altair Community Member
Updated by Jocelyn
Hi everybody,
My dataset consists 4000 examples, 4 special attributes (ID, cluster, text and outlier), and 570 regular attributes from textprocessing. What I have done with the data so far was only to cluster it. Now I have 37 clusters and I want to store the 1 example set for each cluster in my repository.
Thats where my problem is: I think it should be possible with macros, "loop cluster" - and the "store" -operator, but I cant figure out how to set the parameters right.
I have a snippet attached from the data.
And the XML of my process so far:
<?xml version="1.0" encoding="UTF-8"?><process version="8.2.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.2.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="8.2.000" expanded="true" height="68" name="Retrieve Daten KAM clustered (opt.)" width="90" x="112" y="34">
<parameter key="repository_entry" value="//Datenbearbeitung MA/Filter Outliers/Daten KAM clustered (opt.)"/>
<operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes" width="90" x="246" y="34">
<parameter key="attributes" value="ID|label|text"/>
<operator activated="true" class="set_role" compatibility="8.2.000" expanded="true" height="82" name="Set Role" width="90" x="380" y="34">
<parameter key="attribute_name" value="label"/>
<parameter key="target_role" value="cluster"/>
<operator activated="true" class="loop_clusters" compatibility="8.2.000" expanded="true" height="82" name="Loop Clusters" width="90" x="648" y="34">
<operator activated="true" class="filter_examples" compatibility="8.2.000" expanded="true" height="103" name="Filter Examples" width="90" x="179" y="34">
<list key="filters_list">
<parameter key="filters_entry_key" value="label.equals.%{myMacro_0}"/>
</list>
<operator activated="true" class="store" compatibility="8.2.000" expanded="true" height="68" name="Store" width="90" x="648" y="34">
<parameter key="repository_entry" value="999TEST"/>
<connect from_port="cluster subset" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Store" to_port="input"/>
<connect from_op="Store" from_port="through" to_port="out 1"/>
<portSpacing port="source_cluster subset" spacing="0"/>
</process>
<operator activated="true" class="set_macros" compatibility="8.2.000" expanded="true" height="68" name="Set Macros" width="90" x="313" y="136">
<list key="macros">
<parameter key="myMacro_0" value="&quot;cluster_0&quot;"/>
</list>
<connect from_op="Retrieve Daten KAM clustered (opt.)" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Loop Clusters" to_port="example set"/>
<connect from_op="Loop Clusters" from_port="out 1" to_port="result 1"/>
</process>
</process>
My goal is to apply the "Extract Topics from Document (LDA)" operator on every cluster with number of topics = 1 so that I can see the top words for each cluster.
Thank you all in advance
flo
1 - 2 of 21
    User: "MartinLiebig"
    Accepted Answer
    Group into Collection and Loop Collection from Toolbox does it.
    Let me know if you need help with LDA. It's somewhat my baby.
    BR,
    Martin
    Edit: I guess you do not want to use LDA, but simple process documents or so.
    Accepted Answer
    Hi @flo,
    have a look at the attached process. Is should do what you want?
    BR,
    Martin
    <?xml version="1.0" encoding="UTF-8"?><process version="8.2.001">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="8.2.001" expanded="true" name="Process">
    <operator activated="true" class="retrieve" compatibility="8.2.001" expanded="true" height="68" name="Retrieve OpenRanks Reviews Beijing" width="90" x="45" y="34">
    <parameter key="repository_entry" value="data/OpenRanks Reviews Beijing"/>
    <operator activated="true" class="nominal_to_text" compatibility="8.2.001" expanded="true" height="82" name="Nominal to Text" width="90" x="179" y="34">
    <parameter key="attribute" value="Review"/>
    <operator activated="true" class="text:process_document_from_data" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Data" width="90" x="313" y="34">
    <parameter key="vector_creation" value="Term Occurrences"/>
    <parameter key="add_meta_information" value="false"/>
    <parameter key="prune_method" value="percentual"/>
    <parameter key="prune_below_percent" value="5.0"/>
    <list key="specify_weights"/>
    <operator activated="true" class="text:transform_cases" compatibility="8.1.000" expanded="true" height="68" name="Transform Cases" width="90" x="45" y="34"/>
    <operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="246" y="34"/>
    <operator activated="true" class="text:filter_stopwords_english" compatibility="8.1.000" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="514" y="85"/>
    <connect from_port="document" to_op="Transform Cases" to_port="document"/>
    <connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/>
    <connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
    <connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/>
    </process>
    <operator activated="true" class="concurrency:k_means" compatibility="8.2.001" expanded="true" height="82" name="Clustering" width="90" x="447" y="34"/>
    <operator activated="true" class="operator_toolbox:group_into_collection" compatibility="1.3.000-SNAPSHOT" expanded="true" height="82" name="Group Into Collection" width="90" x="715" y="34">
    <parameter key="group_by_attribute" value="cluster"/>
    <operator activated="true" class="loop_collection" compatibility="8.2.001" expanded="true" height="82" name="Loop Collection" width="90" x="849" y="34">
    <operator activated="true" class="extract_macro" compatibility="8.2.001" expanded="true" height="68" name="Extract Macro" width="90" x="45" y="34">
    <parameter key="macro" value="clusterId"/>
    <parameter key="macro_type" value="data_value"/>
    <parameter key="attribute_name" value="cluster"/>
    <parameter key="example_index" value="1"/>
    <list key="additional_macros"/>
    <operator activated="true" class="select_attributes" compatibility="8.2.001" expanded="true" height="82" name="Select Attributes" width="90" x="112" y="136">
    <parameter key="attribute" value="cluster"/>
    <operator activated="true" class="aggregate" compatibility="8.2.001" expanded="true" height="82" name="Aggregate (2)" width="90" x="179" y="34">
    <parameter key="use_default_aggregation" value="true"/>
    <parameter key="default_aggregation_function" value="sum"/>
    <list key="aggregation_attributes"/>
    <operator activated="true" class="transpose" compatibility="8.2.001" expanded="true" height="82" name="Transpose" width="90" x="313" y="34"/>
    <operator activated="true" class="sort" compatibility="8.2.001" expanded="true" height="82" name="Sort" width="90" x="447" y="34">
    <parameter key="attribute_name" value="att_1"/>
    <parameter key="sorting_direction" value="decreasing"/>
    <operator activated="true" class="filter_example_range" compatibility="8.2.001" expanded="true" height="82" name="Filter Example Range" width="90" x="581" y="34">
    <parameter key="first_example" value="1"/>
    <parameter key="last_example" value="5"/>
    <description align="center" color="transparent" colored="false" width="126">Take Top5</description>
    <operator activated="true" class="replace" compatibility="8.2.001" expanded="true" height="82" name="Replace" width="90" x="715" y="34">
    <parameter key="attribute" value="id"/>
    <parameter key="replace_what" value="sum\((.+)\)"/>
    <parameter key="replace_by" value="$1"/>
    <operator activated="true" class="rename" compatibility="8.2.001" expanded="true" height="82" name="Rename" width="90" x="849" y="34">
    <parameter key="old_name" value="att_1"/>
    <parameter key="new_name" value="sum"/>
    <list key="rename_additional_attributes"/>
    <operator activated="true" class="generate_attributes" compatibility="8.2.001" expanded="true" height="82" name="Generate Attributes" width="90" x="983" y="34">
    <parameter key="cluster" value="%{clusterId}"/>
    </list>
    <connect from_port="single" to_op="Extract Macro" to_port="example set"/>
    <connect from_op="Extract Macro" from_port="example set" to_op="Select Attributes" to_port="example set input"/>
    <connect from_op="Select Attributes" from_port="example set output" to_op="Aggregate (2)" to_port="example set input"/>
    <connect from_op="Aggregate (2)" from_port="example set output" to_op="Transpose" to_port="example set input"/>
    <connect from_op="Transpose" from_port="example set output" to_op="Sort" to_port="example set input"/>
    <connect from_op="Sort" from_port="example set output" to_op="Filter Example Range" to_port="example set input"/>
    <connect from_op="Filter Example Range" from_port="example set output" to_op="Replace" to_port="example set input"/>
    <connect from_op="Replace" from_port="example set output" to_op="Rename" to_port="example set input"/>
    <connect from_op="Rename" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
    <connect from_op="Generate Attributes" from_port="example set output" to_port="output 1"/>
    <portSpacing port="source_single" spacing="0"/>
    <portSpacing port="sink_output 1" spacing="0"/>
    <portSpacing port="sink_output 2" spacing="0"/>
    </process>
    <connect from_op="Retrieve OpenRanks Reviews Beijing" from_port="output" to_op="Nominal to Text" to_port="example set input"/>
    <connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/>
    <connect from_op="Process Documents from Data" from_port="example set" to_op="Clustering" to_port="example set"/>
    <connect from_op="Clustering" from_port="clustered set" to_op="Group Into Collection" to_port="exa"/>
    <connect from_op="Group Into Collection" from_port="col" to_op="Loop Collection" to_port="collection"/>
    <connect from_op="Loop Collection" from_port="output 1" to_port="result 1"/>
    <description align="center" color="yellow" colored="false" height="50" resized="true" width="481" x="271" y="235">Task: Calculate the top 5 most frequent words per cluster</description>
    </process>
    </process>
    Edit: Also have a look at this blog post: https://medium.com/@mSchmitz_/understanding-clustering-cf0117148ef4
    i think this is closer to what you really want.
