The dummy operator Read Database (replacing jdbc_connectors:read_database) cannot be executed.
User: "21310122"
New Altair Community Member
Updated by Jocelyn
I creat a process and run it in the RM Studio, it shows correct result in Results panel. Then I want to use it in my program, so I create a test class to run the process by using code like this:
But result isn't what I expected.
Then I debug it and find the reason, "myProcess" created by "processXML" isn't right, but "processXML" is right.
Process myProcess = new Process(processXML);
myProcess.setProcessLocation(new RepositoryProcessLocation(pLoc));
But why? What is a dummy operator?
Does anybody know the answer? Thanks a lot.
1 - 1 of 11
    User: "MartinLiebig"
    Accepted Answer
    JDBC connectors are not part of the open-core but in a seperate extension called jdbc-connections. This extension is not open source.
    Best,
    Martin
