hi everyone,
i have a problem. I made a process that apply discretization box to an example set. Now, i want to save ranges that that process give me as output. Is it possible? Thanks!!
Hi @Nino,
I'm not sure to understand what you want to do.
However does this process answer to your need (if not can you share your process and explain in a precise way what you want to obtain)
<?xml version="1.0" encoding="UTF-8"?><process version="8.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="8.2.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="8.2.000" expanded="true" height="68" name="Retrieve Deals" width="90" x="246" y="34"> <parameter key="repository_entry" value="//Samples/data/Deals"/> </operator> <operator activated="true" class="discretize_by_bins" compatibility="8.2.000" expanded="true" height="103" name="Discretize" width="90" x="380" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Age"/> </operator> <operator activated="true" class="concurrency:loop_values" compatibility="8.2.000" expanded="true" height="82" name="Loop Values" width="90" x="514" y="34"> <parameter key="attribute" value="Age"/> <parameter key="reuse_results" value="true"/> <process expanded="true"> <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes" width="90" x="380" y="34"> <list key="function_descriptions"> <parameter key="Range_%{loop_value}" value="%{loop_value}"/> </list> </operator> <connect from_port="input 1" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes" width="90" x="648" y="34"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="Range.*"/> </operator> <connect from_op="Retrieve Deals" from_port="output" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_op="Loop Values" to_port="input 1"/> <connect from_op="Loop Values" from_port="output 1" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Lionel
