Hello everyone :smileywink:
I currently face a problem with searching for specific keywords within texts that are stored in a Example Set / Dataset.
What I did so far:
Main Process 1: Selected the attribute "text" from the table --> Data to Documents --> Process Documents ( with a Wordlist as input)
Process 2: (getting the wordlist): Retrieve Example Set --> Selecting the Attribute for the keywords with a filter --> process Documents from Data --> connecting the "wor" output to the "wor" input from "Process Documents"
Problem: The results for occurences of the keywords are always the same, even if I change the text files to complete new ones ( I have multiple Example Sets containing multiple text files). The total occurences and Document Occurences are also always the same.
Here is the XML code:
<?xml version="1.0" encoding="UTF-8"?><process version="8.2.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.2.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="8.2.000" expanded="true" height="68" name="Retrieve Names" width="90" x="45" y="391">
<parameter key="repository_entry" value="../../Data/Bundesliga Spieler"/>
<operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select the Surname" width="90" x="246" y="391">
<parameter key="attribute" value="Nachname"/>
<operator activated="true" class="text:process_document_from_data" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Data" width="90" x="514" y="340">
<parameter key="select_attributes_and_weights" value="true"/>
<list key="specify_weights">
<parameter key="Nachname" value="1.0"/>
</list>
<operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="112" y="34"/>
<operator activated="true" class="text:filter_by_length" compatibility="8.1.000" expanded="true" height="68" name="Filter Tokens (2)" width="90" x="313" y="34">
<parameter key="min_chars" value="3"/>
<parameter key="max_chars" value="100"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Tokens (2)" to_port="document"/>
<connect from_op="Filter Tokens (2)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="retrieve" compatibility="8.2.000" expanded="true" height="68" name="DFL Services" width="90" x="45" y="34">
<parameter key="repository_entry" value="../../Data/DFL & Agenda"/>
<operator activated="true" class="retrieve" compatibility="8.2.000" expanded="true" height="68" name="Content Texte" width="90" x="45" y="136">
<parameter key="repository_entry" value="../../Data/ContentTexte"/>
<operator activated="true" class="concurrency:join" compatibility="8.2.000" expanded="true" height="82" name="Join" width="90" x="179" y="85">
<parameter key="use_id_attribute_as_key" value="false"/>
<list key="key_attributes">
<parameter key="article_id" value="metadata_file"/>
</list>
<operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes" width="90" x="380" y="85">
<parameter key="attribute" value="text"/>
<operator activated="true" class="text:data_to_documents" compatibility="8.1.000" expanded="true" height="68" name="Data to Documents" width="90" x="581" y="85">
<parameter key="text" value="1.0"/>
</list>
<operator activated="true" class="text:process_documents" compatibility="8.1.000" expanded="true" height="103" name="Process Documents" width="90" x="916" y="136">
<parameter key="keep_text" value="true"/>
<operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize (2)" width="90" x="313" y="85"/>
<connect from_port="document" to_op="Tokenize (2)" to_port="document"/>
<connect from_op="Tokenize (2)" from_port="document" to_port="document 1"/>
</process>
<connect from_op="Retrieve Names" from_port="output" to_op="Select the Surname" to_port="example set input"/>
<connect from_op="Select the Surname" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="word list" to_op="Process Documents" to_port="word list"/>
<connect from_op="DFL Services" from_port="output" to_op="Join" to_port="left"/>
<connect from_op="Content Texte" from_port="output" to_op="Join" to_port="right"/>
<connect from_op="Join" from_port="join" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Data to Documents" to_port="example set"/>
<connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/>
<connect from_op="Process Documents" from_port="example set" to_port="result 1"/>
<connect from_op="Process Documents" from_port="word list" to_port="result 2"/>
</process>
</process>
I would really appreciate any help!
Kind regards
ngaved91
