hi
I am getting this error while transforming nominal "numerical values" into only numerical, someone knows how to fix it?
Message: org.apache.hive.service.cli.HiveSQLException: Error while processing statement: FAILED: Execution Error, return code 1 from org.apache.hadoop.hive.ql.exec.DDLTask. MetaException(message:1 validation error detected: Value 'SELECT CASE `radoop__tmp_hadoop_1527779946347_xfycxhu`.`duracion` WHEN '-81828' THEN 1 ELSE 0 END AS `duracion__81828`, CASE `radoop__tmp_hadoop_1527779946347_xfycxhu`.`duracion` WHEN '-81840' THEN 1 ELSE 0 END AS `duracion__81840`, CASE `radoop__tmp_hadoop_1527779946347_xfycxhu`.`duracion` WHEN '3802' THEN 1 ELSE 0 END AS `duracion_3802`, CASE
etc.....
