I want to join multiple tables with the ID, but when I use the Join (inner) feature I only get one out of the 3 datasets the other 2 are not included in the final output despite having the information, can someone help me please?
Found the problem, it was ignoring fields with the same value.
Thank you
are you reffering to the IDs? Did you check the keep both join attributes and uncheck the remove double attributes flags?
Best,
Martin
Yes I tried that but still, info from 2 tables are not being showed in the final output table.
btw I am using key attributes, not the check id attributes (I set the role of those variables to be ID but the join tells me that there is not an incoming id when there is)
