Dear all,
During my experimentations, I builded a "classic" process with a model (Random Forest) inside a X-validation operator, inside an Optimize Parameters operator.
After running, I found surprising results :
1. AUC << AUC(pessimistic) < AUC (optimistic)
l
2. The curve ROC associated to AUC is absent !
I used the Generate ROC operator to represent the ROC curve and the shape of this curve is compatible
with the calculated value of AUC (0.499) :
Questions :
- How to interpret this result ?
- Why the ROC curve associated to AUC from the Performance operator is absent ?
- What are the definitions of AUC (pessimistic) / AUC (optimistic) ?
Lionel
NB : The process :
<?xml version="1.0" encoding="UTF-8"?><process version="8.2.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.2.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_direct_mailing_data" compatibility="8.2.000" expanded="true" height="68" name="Generate Direct Mailing Data" width="90" x="45" y="187">
<parameter key="number_examples" value="10000"/>
<operator activated="true" class="split_data" compatibility="8.2.000" expanded="true" height="103" name="Split Data" width="90" x="246" y="136">
<enumeration key="partitions">
<parameter key="ratio" value="0.8"/>
<parameter key="ratio" value="0.2"/>
</enumeration>
<operator activated="true" class="concurrency:optimize_parameters_grid" compatibility="8.2.000" expanded="true" height="145" name="Optimize Parameters (Grid)" width="90" x="380" y="85">
<list key="parameters">
<parameter key="Random Forest.number_of_trees" value="[2;5;10;linear]"/>
<parameter key="Random Forest.maximal_depth" value="[2;5;10;linear]"/>
</list>
<operator activated="true" class="concurrency:cross_validation" compatibility="8.2.000" expanded="true" height="145" name="Cross Validation (2)" width="90" x="112" y="85">
<operator activated="true" class="concurrency:parallel_random_forest" compatibility="8.2.000" expanded="true" height="103" name="Random Forest" width="90" x="179" y="34"/>
<connect from_port="training set" to_op="Random Forest" to_port="training set"/>
<connect from_op="Random Forest" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="8.2.000" expanded="true" height="82" name="Apply Model (2)" width="90" x="112" y="85">
<operator activated="true" class="performance" compatibility="8.2.000" expanded="true" height="82" name="Performance Training" width="90" x="224" y="85"/>
<connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance Training" to_port="labelled data"/>
<connect from_op="Performance Training" from_port="performance" to_port="performance 1"/>
<connect from_op="Performance Training" from_port="example set" to_port="test set results"/>
<portSpacing port="sink_test set results" spacing="0"/>
<portSpacing port="sink_performance 1" spacing="0"/>
<portSpacing port="sink_performance 2" spacing="0"/>
</process>
<connect from_port="input 1" to_op="Cross Validation (2)" to_port="example set"/>
<connect from_op="Cross Validation (2)" from_port="model" to_port="model"/>
<connect from_op="Cross Validation (2)" from_port="test result set" to_port="output 1"/>
<connect from_op="Cross Validation (2)" from_port="performance 1" to_port="performance"/>
<portSpacing port="sink_performance" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<operator activated="true" class="anomalydetection:Generate ROC" compatibility="2.4.001" expanded="true" height="145" name="Generate ROC" width="90" x="581" y="34">
<parameter key="label value for outliers" value="response"/>
<operator activated="true" class="concurrency:loop" compatibility="8.2.000" expanded="true" height="103" name="Loop" width="90" x="581" y="187">
<parameter key="number_of_iterations" value="20"/>
<operator activated="true" class="sample" compatibility="8.2.000" expanded="true" height="82" name="Sample" width="90" x="45" y="136">
<parameter key="sample" value="relative"/>
<list key="sample_size_per_class"/>
<list key="sample_ratio_per_class"/>
<list key="sample_probability_per_class"/>
<parameter key="use_local_random_seed" value="true"/>
<parameter key="local_random_seed" value="%{iteration}"/>
<description align="center" color="transparent" colored="false" width="126">Random Subsets of test data. Random Seed is based on iteration.</description>
<operator activated="true" class="apply_model" compatibility="8.2.000" expanded="true" height="82" name="Apply Model (4)" width="90" x="179" y="34">
<operator activated="true" class="performance" compatibility="8.2.000" expanded="true" height="82" name="Performance Testing" width="90" x="380" y="34"/>
<connect from_port="input 1" to_op="Apply Model (4)" to_port="model"/>
<connect from_port="input 2" to_op="Sample" to_port="example set input"/>
<connect from_op="Sample" from_port="example set output" to_op="Apply Model (4)" to_port="unlabelled data"/>
<connect from_op="Apply Model (4)" from_port="labelled data" to_op="Performance Testing" to_port="labelled data"/>
<connect from_op="Performance Testing" from_port="performance" to_port="output 1"/>
<portSpacing port="source_input 3" spacing="0"/>
</process>
<operator activated="true" breakpoints="after" class="average" compatibility="8.2.000" expanded="true" height="82" name="Average" width="90" x="715" y="187"/>
<operator activated="true" class="t_test" compatibility="8.2.000" expanded="true" height="124" name="T-Test" width="90" x="849" y="136"/>
<connect from_op="Generate Direct Mailing Data" from_port="output" to_op="Split Data" to_port="example set"/>
<connect from_op="Split Data" from_port="partition 1" to_op="Optimize Parameters (Grid)" to_port="input 1"/>
<connect from_op="Split Data" from_port="partition 2" to_op="Loop" to_port="input 2"/>
<connect from_op="Optimize Parameters (Grid)" from_port="performance" to_op="Generate ROC" to_port="performance"/>
<connect from_op="Optimize Parameters (Grid)" from_port="model" to_op="Loop" to_port="input 1"/>
<connect from_op="Optimize Parameters (Grid)" from_port="parameter set" to_port="result 4"/>
<connect from_op="Optimize Parameters (Grid)" from_port="output 1" to_op="Generate ROC" to_port="example set"/>
<connect from_op="Generate ROC" from_port="example set" to_port="result 5"/>
<connect from_op="Generate ROC" from_port="roc set" to_port="result 6"/>
<connect from_op="Generate ROC" from_port="auc" to_port="result 7"/>
<connect from_op="Generate ROC" from_port="performance" to_op="T-Test" to_port="performance 1"/>
<connect from_op="Loop" from_port="output 1" to_op="Average" to_port="averagable 1"/>
<connect from_op="Average" from_port="average" to_op="T-Test" to_port="performance 2"/>
<connect from_op="T-Test" from_port="significance" to_port="result 1"/>
<connect from_op="T-Test" from_port="performance 1" to_port="result 2"/>
<connect from_op="T-Test" from_port="performance 2" to_port="result 3"/>
<portSpacing port="sink_result 5" spacing="0"/>
<portSpacing port="sink_result 6" spacing="0"/>
<portSpacing port="sink_result 7" spacing="0"/>
<portSpacing port="sink_result 8" spacing="0"/>
<portSpacing port="sink_result 9" spacing="0"/>
</process>
</process>
