See Information Selection Extension - it contains FCM. On the "ori" output port it returns clustered data and the partition matrix. "pro" output port contains cluster centers.
Take a look at the log value of the fcm operator. It contains the value of the cost function.
The "mod" output is ClusterModel which you can use to cluster new data.
To compare performances of different methods please use: Item Distribution Performance, Cluster Density Performance, or Performance IS (Clustering).
The last operator takes example set and cluster centers as inputs and then calculates the performance=sum(min(D(x,p)^2), where the sum is over every sample from the exampleSet, and the min - minimum distance is over all cluster centers. In other words it finds the nearest cluster center, and sum the squared distances.
