Hello Guys,
      Im a student working on rapidminer for a bit of time now. I would like to learn a lot more about this topic.
Im thinking of creating a Java App which takes input runs the input through the model the model then classifies it, then the output will be displayed back in the Java App
   I really need help on this one can someone give me a guide on how to start or a sample so I know what direction I should take
The process goes like this:
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.001">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="8.1.001" expanded="true" name="Process">
    <process expanded="true">
      <operator activated="true" class="read_excel" compatibility="8.1.000" expanded="true" height="68" name="Read Excel" width="90" x="45" y="34">
        <parameter key="excel_file" value="C:\Users\JEL\Desktop\100% ENGLISH DATA  (11).xlsx"/>
        <parameter key="sheet_selection" value="sheet number"/>
        <parameter key="sheet_number" value="4"/>
        <parameter key="imported_cell_range" value="A1:C4001"/>
        <parameter key="first_row_as_names" value="false"/>
        <list key="annotations">
          <parameter key="0" value="Name"/>
        </list>
        <parameter key="date_format" value=""/>
        <parameter key="time_zone" value="SYSTEM"/>
        <parameter key="locale" value="English (United States)"/>
        <parameter key="read_all_values_as_polynominal" value="false"/>
          <parameter key="0" value="tweet id.true.integer.id"/>
          <parameter key="1" value="Text.true.text.attribute"/>
          <parameter key="2" value="Actual.true.nominal.label"/>
        </list>
        <parameter key="read_not_matching_values_as_missings" value="true"/>
        <parameter key="datamanagement" value="double_array"/>
        <parameter key="data_management" value="auto"/>
      <operator activated="true" class="read_excel" compatibility="8.1.000" expanded="true" height="68" name="Read Excel (2)" width="90" x="45" y="187">
        <parameter key="sheet_number" value="5"/>
        <parameter key="imported_cell_range" value="A1:C1001"/>
        </list>
        </list>
      <operator activated="true" class="text:process_document_from_data" compatibility="7.2.001" expanded="true" height="82" name="Process Documents from Data" width="90" x="179" y="34">
        <parameter key="create_word_vector" value="true"/>
        <parameter key="vector_creation" value="TF-IDF"/>
        <parameter key="add_meta_information" value="true"/>
        <parameter key="keep_text" value="false"/>
        <parameter key="prune_method" value="none"/>
        <parameter key="prune_below_percent" value="3.0"/>
        <parameter key="prune_above_percent" value="30.0"/>
        <parameter key="prune_below_rank" value="0.05"/>
        <parameter key="prune_above_rank" value="0.95"/>
        <parameter key="datamanagement" value="double_sparse_array"/>
        <parameter key="select_attributes_and_weights" value="false"/>
        <list key="specify_weights"/>
          <operator activated="true" class="text:transform_cases" compatibility="7.2.001" expanded="true" height="68" name="Transform Cases" width="90" x="45" y="85">
            <parameter key="transform_to" value="lower case"/>
          <operator activated="false" class="text:replace_tokens" compatibility="7.2.001" expanded="true" height="68" name="Replace Tokens (2)" width="90" x="916" y="391">
            <list key="replace_dictionary">
              <parameter key="<3" value="."/>
              <parameter key=":\)" value="."/>
              <parameter key=":\(" value="."/>
              <parameter key=">\:\)" value="."/>
              <parameter key=":\|" value="."/>
              <parameter key=">\:\(" value="."/>
              <parameter key=">\:\|" value="."/>
              <parameter key=":\d" value="."/>
            </list>
          <operator activated="false" class="text:replace_tokens" compatibility="7.2.001" expanded="true" height="68" name="Emoticons to Words" width="90" x="112" y="187">
              <parameter key="<3" value="Heart "/>
              <parameter key=":\)" value="Smiley "/>
              <parameter key=":\(" value="Sad Face "/>
              <parameter key=">\:\)" value="Evil Smile"/>
              <parameter key=":\|" value="Not Ammused "/>
              <parameter key=">\:\(" value="Angry Sad Face "/>
              <parameter key=">\:\|" value="Angry and Not Ammused "/>
              <parameter key=":\d" value="Happy Face"/>
              <parameter key=":\-\)" value="Happy Face"/>
              <parameter key=":\-\(" value="Sad Face"/>
            </list>
          <operator activated="true" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Remove unwatned symbols" width="90" x="179" y="34">
            <parameter key="mode" value="specify characters"/>
            <parameter key="characters" value="~`@#$%^&amp;*()_+|-=\{}[]:";'<>,./1234567890"/>
            <parameter key="expression" value="[*]"/>
            <parameter key="language" value="English"/>
            <parameter key="max_token_length" value="3"/>
          <operator activated="false" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Remove Periods" width="90" x="112" y="289">
            <parameter key="mode" value="regular expression"/>
            <parameter key="characters" value=".:"/>
            <parameter key="expression" value="[.]"/>
          <operator activated="false" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Remove "" width="90" x="112" y="391">
            <parameter key="expression" value="["]"/>
          <operator activated="false" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Remove '" width="90" x="112" y="493">
            <parameter key="expression" value="[']"/>
          <operator activated="false" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Remove ~" width="90" x="246" y="493">
            <parameter key="expression" value="[~]"/>
          <operator activated="false" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Remove num" width="90" x="246" y="391">
            <parameter key="expression" value="[[0-9]]"/>
          <operator activated="false" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Remove *" width="90" x="246" y="289">
          <operator activated="false" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Remove -" width="90" x="313" y="187">
            <parameter key="expression" value="[-]"/>
          <operator activated="true" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Tokenize (2)" width="90" x="313" y="85">
            <parameter key="mode" value="linguistic tokens"/>
            <parameter key="expression" value="[!]"/>
          <operator activated="true" class="text:filter_stopwords_english" compatibility="7.2.001" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="447" y="85"/>
          <operator activated="true" class="text:filter_by_length" compatibility="7.2.001" expanded="true" height="68" name="Filter Tokens (by Length)" width="90" x="581" y="85">
            <parameter key="min_chars" value="2"/>
            <parameter key="max_chars" value="50"/>
          <operator activated="false" class="text:generate_n_grams_terms" compatibility="7.2.001" expanded="true" height="68" name="Generate n-Grams (2)" width="90" x="715" y="238">
            <parameter key="max_length" value="2"/>
          <operator activated="true" class="text:stem_porter" compatibility="7.2.001" expanded="true" height="68" name="Stem (Porter)" width="90" x="849" y="85"/>
          <connect from_port="document" to_op="Transform Cases" to_port="document"/>
          <connect from_op="Transform Cases" from_port="document" to_op="Remove unwatned symbols" to_port="document"/>
          <connect from_op="Remove unwatned symbols" from_port="document" to_op="Tokenize (2)" to_port="document"/>
          <connect from_op="Remove Periods" from_port="document" to_op="Remove "" to_port="document"/>
          <connect from_op="Remove "" from_port="document" to_op="Remove '" to_port="document"/>
          <connect from_op="Remove '" from_port="document" to_op="Remove ~" to_port="document"/>
          <connect from_op="Remove ~" from_port="document" to_op="Remove num" to_port="document"/>
          <connect from_op="Remove num" from_port="document" to_op="Remove *" to_port="document"/>
          <connect from_op="Remove *" from_port="document" to_op="Remove -" to_port="document"/>
          <connect from_op="Tokenize (2)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
          <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
          <connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Stem (Porter)" to_port="document"/>
          <connect from_op="Stem (Porter)" from_port="document" to_port="document 1"/>
          <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="585" y="588">Type your comment</description>
          <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="366" y="595">Type your comment</description>
          <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="802" y="586">Type your comment</description>
        </process>
      <operator activated="true" class="set_role" compatibility="8.1.001" expanded="true" height="82" name="Set Role" width="90" x="313" y="34">
        <parameter key="attribute_name" value="Actual"/>
      <operator activated="true" class="select_attributes" compatibility="8.1.001" expanded="true" height="82" name="Select Attributes" width="90" x="447" y="34">
        <parameter key="attribute_filter_type" value="no_missing_values"/>
        <parameter key="attribute" value=""/>
        <parameter key="attributes" value="Actual||ID"/>
      <operator activated="true" class="concurrency:cross_validation" compatibility="8.1.001" expanded="true" height="145" name="Cross Validation" width="90" x="648" y="34">
        <parameter key="split_on_batch_attribute" value="false"/>
        <parameter key="leave_one_out" value="false"/>
        <parameter key="number_of_folds" value="10"/>
        <parameter key="sampling_type" value="automatic"/>
        <parameter key="use_local_random_seed" value="true"/>
        <parameter key="local_random_seed" value="12345"/>
        <parameter key="enable_parallel_execution" value="true"/>
          <operator activated="true" class="k_nn" compatibility="8.1.001" expanded="true" height="82" name="k-NN (2)" width="90" x="313" y="85">
            <parameter key="k" value="81"/>
            <parameter key="weighted_vote" value="true"/>
            <parameter key="measure_types" value="MixedMeasures"/>
            <parameter key="mixed_measure" value="MixedEuclideanDistance"/>
            <parameter key="nominal_measure" value="NominalDistance"/>
            <parameter key="numerical_measure" value="EuclideanDistance"/>
            <parameter key="divergence" value="GeneralizedIDivergence"/>
            <parameter key="kernel_type" value="radial"/>
            <parameter key="kernel_gamma" value="1.0"/>
            <parameter key="kernel_sigma1" value="1.0"/>
            <parameter key="kernel_sigma2" value="0.0"/>
            <parameter key="kernel_sigma3" value="2.0"/>
            <parameter key="kernel_degree" value="3.0"/>
            <parameter key="kernel_shift" value="1.0"/>
            <parameter key="kernel_a" value="1.0"/>
            <parameter key="kernel_b" value="0.0"/>
          <connect from_port="training set" to_op="k-NN (2)" to_port="training set"/>
          <connect from_op="k-NN (2)" from_port="model" to_port="model"/>
          <portSpacing port="source_training set" spacing="0"/>
          <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="584" y="119">Type your comment</description>
          <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="547" y="237">Type your comment</description>
        </process>
          <operator activated="true" class="apply_model" compatibility="8.1.001" expanded="true" height="82" name="Apply Model (2)" width="90" x="45" y="136">
            <parameter key="create_view" value="false"/>
          <operator activated="true" class="performance_classification" compatibility="8.1.001" expanded="true" height="82" name="Performance (2)" width="90" x="45" y="34">
            <parameter key="main_criterion" value="kappa"/>
            <parameter key="accuracy" value="true"/>
            <parameter key="classification_error" value="true"/>
            <parameter key="kappa" value="true"/>
            <parameter key="weighted_mean_recall" value="true"/>
            <parameter key="weighted_mean_precision" value="true"/>
            <parameter key="spearman_rho" value="false"/>
            <parameter key="kendall_tau" value="true"/>
            <parameter key="absolute_error" value="true"/>
            <parameter key="relative_error" value="false"/>
            <parameter key="relative_error_lenient" value="false"/>
            <parameter key="relative_error_strict" value="false"/>
            <parameter key="normalized_absolute_error" value="false"/>
            <parameter key="root_mean_squared_error" value="true"/>
            <parameter key="root_relative_squared_error" value="false"/>
            <parameter key="squared_error" value="false"/>
            <parameter key="correlation" value="true"/>
            <parameter key="squared_correlation" value="false"/>
            <parameter key="cross-entropy" value="false"/>
            <parameter key="margin" value="true"/>
            <parameter key="soft_margin_loss" value="false"/>
            <parameter key="logistic_loss" value="false"/>
            <parameter key="skip_undefined_labels" value="true"/>
            <parameter key="use_example_weights" value="true"/>
            <list key="class_weights"/>
          <connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
          <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/>
          <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/>
          <connect from_op="Performance (2)" from_port="performance" to_port="performance 1"/>
          <connect from_op="Performance (2)" from_port="example set" to_port="test set results"/>
          <portSpacing port="sink_test set results" spacing="0"/>
          <portSpacing port="sink_performance 1" spacing="0"/>
          <portSpacing port="sink_performance 2" spacing="0"/>
          <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="141" y="208">Type your comment</description>
          <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="246" y="157">Type your comment</description>
        </process>
      <operator activated="true" class="text:process_document_from_data" compatibility="7.2.001" expanded="true" height="82" name="Process Documents from Data (3)" width="90" x="179" y="289">
          <operator activated="true" class="text:transform_cases" compatibility="7.2.001" expanded="true" height="68" name="Transform Cases (3)" width="90" x="45" y="85">
          <operator activated="false" class="text:replace_tokens" compatibility="7.2.001" expanded="true" height="68" name="Replace Tokens (5)" width="90" x="916" y="238">
            </list>
          <operator activated="false" class="text:replace_tokens" compatibility="7.2.001" expanded="true" height="68" name="Emoticons to Words (2)" width="90" x="112" y="187">
            </list>
          <operator activated="false" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Remove Periods (3)" width="90" x="112" y="289">
          <operator activated="false" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Remove " (3)" width="90" x="112" y="391">
          <operator activated="false" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Remove ' (3)" width="90" x="112" y="493">
          <operator activated="false" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Remove ~ (2)" width="90" x="246" y="493">
          <operator activated="false" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Remove num (2)" width="90" x="246" y="391">
          <operator activated="false" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Remove * (2)" width="90" x="246" y="289">
          <operator activated="false" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Remove - (2)" width="90" x="313" y="187">
          <operator activated="true" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Remove unwatned symbols (3)" width="90" x="246" y="85">
          <operator activated="true" class="text:tokenize" compatibility="7.2.001" expanded="true" height="68" name="Tokenize (4)" width="90" x="380" y="85">
          <operator activated="true" class="text:filter_stopwords_english" compatibility="7.2.001" expanded="true" height="68" name="Filter Stopwords (3)" width="90" x="514" y="85"/>
          <operator activated="true" class="text:filter_by_length" compatibility="7.2.001" expanded="true" height="68" name="Filter Tokens (3)" width="90" x="648" y="85">
          <operator activated="false" class="text:generate_n_grams_terms" compatibility="7.2.001" expanded="true" height="68" name="Generate n-Grams (3)" width="90" x="715" y="238">
          <operator activated="true" class="text:stem_porter" compatibility="7.2.001" expanded="true" height="68" name="Stem (3)" width="90" x="849" y="85"/>
          <connect from_port="document" to_op="Transform Cases (3)" to_port="document"/>
          <connect from_op="Transform Cases (3)" from_port="document" to_op="Remove unwatned symbols (3)" to_port="document"/>
          <connect from_op="Remove Periods (3)" from_port="document" to_op="Remove " (3)" to_port="document"/>
          <connect from_op="Remove " (3)" from_port="document" to_op="Remove ' (3)" to_port="document"/>
          <connect from_op="Remove ' (3)" from_port="document" to_op="Remove ~ (2)" to_port="document"/>
          <connect from_op="Remove ~ (2)" from_port="document" to_op="Remove num (2)" to_port="document"/>
          <connect from_op="Remove num (2)" from_port="document" to_op="Remove * (2)" to_port="document"/>
          <connect from_op="Remove * (2)" from_port="document" to_op="Remove - (2)" to_port="document"/>
          <connect from_op="Remove unwatned symbols (3)" from_port="document" to_op="Tokenize (4)" to_port="document"/>
          <connect from_op="Tokenize (4)" from_port="document" to_op="Filter Stopwords (3)" to_port="document"/>
          <connect from_op="Filter Stopwords (3)" from_port="document" to_op="Filter Tokens (3)" to_port="document"/>
          <connect from_op="Filter Tokens (3)" from_port="document" to_op="Stem (3)" to_port="document"/>
          <connect from_op="Stem (3)" from_port="document" to_port="document 1"/>
          <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="579" y="555">Type your comment</description>
          <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="396" y="555">Type your comment</description>
          <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="767" y="552">Type your comment</description>
        </process>
      <operator activated="true" class="set_role" compatibility="8.1.001" expanded="true" height="82" name="Set Role (2)" width="90" x="313" y="187">
      <operator activated="true" class="select_attributes" compatibility="8.1.001" expanded="true" height="82" name="Select Attributes (2)" width="90" x="447" y="187">
        <parameter key="attributes" value="ID||Actual"/>
      <operator activated="true" class="apply_model" compatibility="8.1.001" expanded="true" height="82" name="Apply Model" width="90" x="782" y="340">
      <connect from_op="Read Excel" from_port="output" to_op="Process Documents from Data" to_port="example set"/>
      <connect from_op="Read Excel (2)" from_port="output" to_op="Process Documents from Data (3)" to_port="example set"/>
      <connect from_op="Process Documents from Data" from_port="example set" to_op="Set Role" to_port="example set input"/>
      <connect from_op="Process Documents from Data" from_port="word list" to_op="Process Documents from Data (3)" to_port="word list"/>
      <connect from_op="Set Role" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
      <connect from_op="Select Attributes" from_port="example set output" to_op="Cross Validation" to_port="example set"/>
      <connect from_op="Cross Validation" from_port="model" to_op="Apply Model" to_port="model"/>
      <connect from_op="Cross Validation" from_port="example set" to_port="result 1"/>
      <connect from_op="Cross Validation" from_port="test result set" to_port="result 2"/>
      <connect from_op="Cross Validation" from_port="performance 1" to_port="result 3"/>
      <connect from_op="Process Documents from Data (3)" from_port="example set" to_op="Set Role (2)" to_port="example set input"/>
      <connect from_op="Process Documents from Data (3)" from_port="word list" to_port="result 6"/>
      <connect from_op="Set Role (2)" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/>
      <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Apply Model" to_port="unlabelled data"/>
      <connect from_op="Apply Model" from_port="labelled data" to_port="result 4"/>
      <connect from_op="Apply Model" from_port="model" to_port="result 5"/>
      <portSpacing port="sink_result 5" spacing="0"/>
      <portSpacing port="sink_result 6" spacing="0"/>
      <portSpacing port="sink_result 7" spacing="0"/>
      <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="918" y="593">Type your comment</description>
      <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="784" y="149">Type your comment</description>
    </process>
</process>
