HelloI used the Silhouette and cpcc criteria to evaluate clusteringBut as a result, the amount of unknow or infinite appears.What does it mean?Was clustering wrong?what is the reason?Thanks a lot
hello @maral welcome to the community! Some quick recommendations for you:• Post your XML process here in this thread (see https://youtu.be/KkgB5QXWXJ8 and "Read Before Posting" on right when you reply)• Attach your dataset if possible (use a fictionalized version if there are privacy concerns)• Make sure you have all necessary extensions installed (see https://youtu.be/pjBqG3xtXx4)Scott
