Hello ,
i want to install an extension on rapidminer server.I follow the instructions from here:
https://community.rapidminer.com/t5/RapidMiner-Server-Knowledge-Base/How-do-I-install-Extensions-for-RapidMiner-Server/tac-p/49134#M78
When i went to server settings there was a path for com.rapidanalytics.plugindir , so when i search for it , appeared a 'There is no such path ' message . I search a little bit and i find that the plugins folder was into a folder like this 'deployment5453132' and inside him there was a javascript file :'jquery.desaturate' . So i paste the extension jar file into plugins file and i re-start the server . What i found out is that the folder that i paste the extension was deleted and the folder ''deployment5453132' was replaced with another 'deployment444445' -noticed that the numbers have changed -and into the plugin folder there was only the javascript file .
So I create a folder outside of rapidminer-server's 'standalone' folder , i paste the rmx_text jar file and i write the path to service settings , re-start the server but the extension doesn't install.
What am i doing wrong?
Thank you in advance!
