I want to classify a time sequence of OHLC data using LSTM.
This exampleset is converted to samples, time steps, and features to feed the LSTM using a reshape layer.
When I run this model I get an error message as shown in the following picture.
What am I doing wrong?
My model is listed below.
My input exampleset consist out of 2000 examples of OHLC data.
I reshape this data to 100 samples of 20 timesteps of 4 (OHLC) features.
My label is PhasesNum. It contains 3 classes indicated with the real values 10, 100, and 1000.
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.1.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="8.1.001" expanded="true" height="68" name="Retrieve Data" width="90" x="45" y="34">
<parameter key="repository_entry" value="../Data/inputdata"/>
<operator activated="true" class="select_attributes" compatibility="8.1.001" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="34">
<parameter key="attribute" value=""/>
<parameter key="attributes" value="Close|High|Low|Open|PhasesNum"/>
<operator activated="true" class="numerical_to_real" compatibility="8.1.001" expanded="true" height="82" name="Numerical to Real" width="90" x="313" y="34">
<parameter key="attributes" value="PhasesNum"/>
<parameter key="value_type" value="numeric"/>
<parameter key="except_value_type" value="real"/>
<parameter key="block_type" value="value_series"/>
<parameter key="except_block_type" value="value_series_end"/>
<operator activated="true" class="set_role" compatibility="8.1.001" expanded="true" height="82" name="Set Role" width="90" x="447" y="34">
<parameter key="attribute_name" value="PhasesNum"/>
<list key="set_additional_roles">
<parameter key="Close" value="regular"/>
<parameter key="High" value="regular"/>
<parameter key="Low" value="regular"/>
<parameter key="Open" value="regular"/>
</list>
<operator activated="true" class="filter_example_range" compatibility="8.1.001" expanded="true" height="82" name="Filter Example Range" width="90" x="45" y="136">
<parameter key="first_example" value="1"/>
<parameter key="last_example" value="2000"/>
<parameter key="invert_filter" value="false"/>
<operator activated="true" class="normalize" compatibility="8.1.001" expanded="true" height="103" name="Normalize" width="90" x="179" y="136">
<parameter key="return_preprocessing_model" value="false"/>
<parameter key="create_view" value="false"/>
<parameter key="attributes" value="Close|High|Low|Open"/>
<parameter key="method" value="Z-transformation"/>
<parameter key="min" value="0.0"/>
<parameter key="max" value="1.0"/>
<parameter key="allow_negative_values" value="false"/>
<operator activated="true" class="multiply" compatibility="8.1.001" expanded="true" height="103" name="Multiply" width="90" x="313" y="136"/>
<operator activated="true" class="keras:sequential" compatibility="1.0.003" expanded="true" height="166" name="Keras Model" width="90" x="246" y="289">
<parameter key="input shape" value="(2000,4)"/>
<parameter key="loss" value="categorical_crossentropy"/>
<parameter key="optimizer" value="Adam"/>
<parameter key="learning rate" value="0.001"/>
<parameter key="momentum" value="0.0"/>
<parameter key="rho" value="0.9"/>
<parameter key="beta 1" value="0.999"/>
<parameter key="beta 2" value="0.999"/>
<parameter key="epsilon" value="1.0E-8"/>
<parameter key="decay" value="0.0"/>
<parameter key="schedule decay" value="0.004"/>
<parameter key="Nesterov" value="false"/>
<parameter key="use metric" value="false"/>
<enumeration key="metric"/>
<parameter key="epochs" value="128"/>
<parameter key="batch size" value="100"/>
<enumeration key="callbacks">
<parameter key="callbacks" value="TensorBoard(log_dir='./logs', histogram_freq=0, write_graph=True, write_images=False, embeddings_freq=0, embeddings_layer_names=None, embeddings_metadata=None)"/>
</enumeration>
<parameter key="verbose" value="1"/>
<parameter key="validation split" value="0.0"/>
<parameter key="shuffle" value="false"/>
<parameter key="fix seed" value="false"/>
<parameter key="random seed" value="0"/>
<operator activated="true" class="keras:core_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Core Layer" width="90" x="112" y="34">
<parameter key="layer_type" value="Reshape"/>
<parameter key="no_units" value="1"/>
<parameter key="activation_function" value="None"/>
<parameter key="use_bias" value="true"/>
<parameter key="kernel_initializer" value="glorot_uniform(seed=None)"/>
<parameter key="bias_initializer" value="Zeros()"/>
<parameter key="kernel_regularizer" value="None"/>
<parameter key="bias_regularizer" value="None"/>
<parameter key="activity_regularizer" value="None"/>
<parameter key="kernel_constraint" value="None"/>
<parameter key="bias_constraint" value="None"/>
<parameter key="rate" value="0.1"/>
<parameter key="noise_shape" value="None"/>
<parameter key="seed" value="None"/>
<parameter key="target_shape" value="(100,20,4)"/>
<parameter key="dims" value="1.1"/>
<parameter key="repetition_factor" value="1"/>
<parameter key="function" value="None"/>
<parameter key="l1" value="0.0"/>
<parameter key="l2" value="0.0"/>
<parameter key="mask_value" value="0.0"/>
<operator activated="true" class="keras:recurrent_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Recurrent Layer" width="90" x="313" y="34">
<parameter key="layer_type" value="LSTM"/>
<parameter key="no_units" value="3"/>
<parameter key="activation" value="softmax"/>
<parameter key="recurrent_activation" value="sigmoid"/>
<parameter key="recurrent_initializer" value="glorot_uniform(seed=None)"/>
<parameter key="unit_forget_bias" value="true"/>
<parameter key="recurrent_regularizer" value="None"/>
<parameter key="recurrent_constraint" value="None"/>
<parameter key="dropout" value="0.0"/>
<parameter key="recurrent_dropout" value="0.0"/>
<parameter key="stateful" value="true"/>
<parameter key="unroll" value="false"/>
<parameter key="implementation" value="0"/>
<connect from_op="Add Core Layer" from_port="layers 1" to_op="Add Recurrent Layer" to_port="layers"/>
<connect from_op="Add Recurrent Layer" from_port="layers 1" to_port="layers 1"/>
<portSpacing port="sink_layers 1" spacing="0"/>
<portSpacing port="sink_layers 2" spacing="0"/>
</process>
<operator activated="true" class="keras:apply" compatibility="1.0.003" expanded="true" height="82" name="Apply Keras Model" width="90" x="447" y="289">
<parameter key="batch_size" value="100"/>
<parameter key="verbose" value="0"/>
<connect from_op="Retrieve Data" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Numerical to Real" to_port="example set input"/>
<connect from_op="Numerical to Real" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Filter Example Range" to_port="example set input"/>
<connect from_op="Filter Example Range" from_port="example set output" to_op="Normalize" to_port="example set input"/>
<connect from_op="Normalize" from_port="example set output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Apply Keras Model" to_port="unlabelled data"/>
<connect from_op="Multiply" from_port="output 2" to_op="Keras Model" to_port="training set"/>
<connect from_op="Keras Model" from_port="model" to_op="Apply Keras Model" to_port="model"/>
<connect from_op="Apply Keras Model" from_port="labelled data" to_port="result 1"/>
</process>
</process>
