Hi, I've got a Twitter data entryI want to use WordPressBut this error appearsPlease guide.Send me a screenshot of the performanceThanks
Hi @ahootanha
Could you confirm that you have pointed the right directory containing stem dictionary for "Open WordNet Dictionary"?
Could you please take a screenshot after clicking on 'MoreInfo'
Also please share the Studio log file found here: C:\users\<username>\.RapidMiner\
This will help us debug the issue easily.
Thanks,
Hi, Thanks for your replyI've run the program many times. But this error is repeated every timePlease guideThanks
I have few similar process where I use Open wordnet dictionary.
As shown in below screenshot I point the directory to the folder where I have dictionary saved in following formats:
format of dictionariesProcess using Open wordnet dictionary
Not sure what format you have saved your stem dictionary. The error seems to be related to file formats, hence it's not able to parse or read the files.
Also please share the log files to help debug the issue here.
It will in your .RapidMiner folder :C:\users\<username>\.Rapidminer \**.log
Hope this helps.
Cheers,
Pavithra
HelloI saw this in the log fileThe dictionary was just like youPlease guideThanks
Could you please attach the .log file here. The screenshot of the log file doesn't really help.
I posted the filePlease guideThanks
HelloCan no one help me?Very necessaryPlease help me
hello @ahootanha please be patient. This is a community forum - people volunteer their time to help users when they can.
[EDIT: I just looked at your PDF. You only posted a fragment of your log file rather than the whole thing but it's pretty clear that the Wordnet dictionary is the problem here:
SEVERE: Process failed: Error reading F:\WordNet-3.0: Could not open dictionary from directoryF:\WordNet-3.0com.rapidminer.operator.UserError: Error reading F:\WordNet-3.0: Could not open dictionary fromdirectory F:\WordNet-3.0
Scott
Hello Forgive me Believe me, I'm very caught I thank you and the community What should i do now To overcome the problem Please guide Thanks & Regards
hello @ahootanha - so I still think the problem is the dictionary path that you're giving that Wordnet operator. Perhaps you can post your XML and your dataset so we can see what you're doing?
@ahootanha did you try switching the parameter from 'directory' to 'resource?' I seem to remember that at times it causes a conflict that can be resolved by toggling one or the other.
HelloThank you for your attentionI used this data for the exam (Posted)I changed my data many times, but there is still the same error.May I ask you to do it and send your rapidminer file? Along with the wordnet Dictionary?I will be grateful.Thanks
HelloHonorable professorsPlease send me an example that uses Twitter data.Anything I did not run. And I see the same error ...Thanks
