Hello,how to limit an attribute (numerical) value to a specified maximum ?If my attribute = 1.5 then my attribute = 1 Thanks
you can use Generate Attributes for this. Something like
if(attribute=1.5,1,attribute)
should do it.
Best,
Martin
Thank you very much
@bibo59 You might consider making your expression a bit more flexible. Martin's solution works if the higher value is exactly 1.5, but not for other values. So instead you could use an if statement like this: if(attribute>1,1,attribute).
Or you could directly use the MIN function like this: min(1,attribute).
