hello
i'm a new user of RapidMiner, i will thinkfull if you help me to know how can i make a weather prediction (rainfull) from a database
Hi @oussama_salhi89,
It's difficult to help you without dataset. Can you share an extract of data of your database and explain what exactly you want to predict.
Lionel
Hi @lionelderkrikor ;
thank you for replying me
this is my database
i have the mesure of rainfall since 1979 until 2011 in milimeter the object is to predict the evolution of rainfall in the comming years
oussama
Hi again Oussama,
1. Here you can find a process for this time series project :
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.000"> <context> <input/> <output/> <macros> <macro> <key>futureMonths</key> <value>15</value> </macro> <macro> <key>horizon</key> <value>1</value> </macro> <macro> <key>windowSize</key> <value>6</value> </macro> </macros> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="8.1.000" expanded="true" height="68" name="Read Excel" width="90" x="45" y="85"> <parameter key="excel_file" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\Tests_Rapidminer\Precipitations_forecast\Precipitations_forecast.xlsx"/> <parameter key="imported_cell_range" value="A1:B33"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="Year.true.polynominal.attribute"/> <parameter key="1" value="Precipitations.true.numeric.attribute"/> </list> </operator> <operator activated="true" class="subprocess" compatibility="8.1.000" expanded="true" height="82" name="Set Predictions_Params" width="90" x="179" y="85"> <process expanded="true"> <operator activated="true" class="set_macro" compatibility="8.1.000" expanded="true" height="82" name="Set Window_Size" width="90" x="45" y="34"> <parameter key="macro" value="WindowSize"/> <parameter key="value" value="10"/> </operator> <operator activated="true" class="set_macro" compatibility="8.1.000" expanded="true" height="82" name="Set Horizon" width="90" x="179" y="34"> <parameter key="macro" value="horizon"/> <parameter key="value" value="1"/> </operator> <operator activated="true" class="set_macro" compatibility="8.1.000" expanded="true" height="82" name="Set Future_Years" width="90" x="313" y="34"> <parameter key="macro" value="futureYears"/> <parameter key="value" value="7"/> </operator> <connect from_port="in 1" to_op="Set Window_Size" to_port="through 1"/> <connect from_op="Set Window_Size" from_port="through 1" to_op="Set Horizon" to_port="through 1"/> <connect from_op="Set Horizon" from_port="through 1" to_op="Set Future_Years" to_port="through 1"/> <connect from_op="Set Future_Years" from_port="through 1" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="split" compatibility="8.1.000" expanded="true" height="82" name="Split" width="90" x="313" y="85"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Year"/> <parameter key="split_pattern" value="-"/> </operator> <operator activated="true" class="rename" compatibility="8.1.000" expanded="true" height="82" name="Rename (2)" width="90" x="447" y="85"> <parameter key="old_name" value="Year_1"/> <parameter key="new_name" value="Year"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="nominal_to_date" compatibility="8.1.000" expanded="true" height="82" name="Nominal to Date" width="90" x="648" y="85"> <parameter key="attribute_name" value="Year"/> <parameter key="date_format" value="YYYY"/> </operator> <operator activated="true" class="set_role" compatibility="5.3.013" expanded="true" height="82" name="Set Role" width="90" x="782" y="85"> <parameter key="attribute_name" value="Year"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="select_attributes" compatibility="8.1.000" expanded="true" height="82" name="Select Attributes" width="90" x="916" y="85"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Precipitations"/> </operator> <operator activated="true" class="filter_examples" compatibility="6.4.000" expanded="true" height="103" name="Filter Examples" width="90" x="1050" y="85"> <parameter key="condition_class" value="no_missing_attributes"/> <list key="filters_list"/> </operator> <operator activated="true" class="series:windowing" compatibility="5.2.000" expanded="true" height="82" name="Windowing for Training" width="90" x="1184" y="85"> <parameter key="window_size" value="%{WindowSize}"/> <parameter key="create_label" value="true"/> <parameter key="label_attribute" value="Precipitations"/> <parameter key="horizon" value="%{horizon}"/> </operator> <operator activated="true" class="h2o:deep_learning" compatibility="7.6.001" expanded="true" height="82" name="Deep Learning" width="90" x="1318" y="34"> <enumeration key="hidden_layer_sizes"> <parameter key="hidden_layer_sizes" value="50"/> <parameter key="hidden_layer_sizes" value="50"/> </enumeration> <enumeration key="hidden_dropout_ratios"/> <list key="expert_parameters"/> <list key="expert_parameters_"/> </operator> <operator activated="true" class="series:windowing" compatibility="5.2.000" expanded="true" height="82" name="Windowing for Application" width="90" x="1318" y="136"> <parameter key="window_size" value="%{WindowSize}"/> <parameter key="label_attribute" value="inputYt"/> </operator> <operator activated="true" class="extract_macro" compatibility="8.1.000" expanded="true" height="68" name="Extract Example Count" width="90" x="1519" y="136"> <parameter key="macro" value="exampleCount"/> <list key="additional_macros"/> </operator> <operator activated="true" class="filter_example_range" compatibility="8.1.000" expanded="true" height="82" name="Filter Example Range" width="90" x="1653" y="136"> <parameter key="first_example" value="%{exampleCount}"/> <parameter key="last_example" value="%{exampleCount}"/> </operator> <operator activated="true" class="remember" compatibility="8.1.000" expanded="true" height="68" name="Remember" width="90" x="1787" y="136"> <parameter key="name" value="data"/> </operator> <operator activated="true" class="loop" compatibility="8.1.000" expanded="true" height="82" name="Loop" width="90" x="1519" y="34"> <parameter key="iterations" value="%{futureYears}"/> <process expanded="true"> <operator activated="true" class="recall" compatibility="8.1.000" expanded="true" height="68" name="Recall" width="90" x="45" y="136"> <parameter key="name" value="data"/> </operator> <operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="82" name="Apply Model" width="90" x="179" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="multiply" compatibility="8.1.000" expanded="true" height="103" name="Multiply" width="90" x="447" y="30"/> <operator activated="true" class="materialize_data" compatibility="8.1.000" expanded="true" height="82" name="Materialize Data (2)" width="90" x="179" y="165"/> <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="82" name="Increase Date (2)" width="90" x="313" y="165"> <list key="function_descriptions"> <parameter key="Year" value="date_add(Year, 1, DATE_UNIT_YEAR)"/> </list> </operator> <operator activated="true" class="set_role" compatibility="5.3.013" expanded="true" height="82" name="Set Role (2)" width="90" x="447" y="165"> <parameter key="attribute_name" value="prediction(label)"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="select_attributes" compatibility="8.1.000" expanded="true" height="82" name="Select Attributes (3)" width="90" x="179" y="289"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Precipitations-9"/> <parameter key="invert_selection" value="true"/> </operator> <operator activated="true" class="rename" compatibility="8.1.000" expanded="true" height="82" name="Rename" width="90" x="313" y="289"> <parameter key="old_name" value="Precipitations-8"/> <parameter key="new_name" value="Precipitations-9"/> <list key="rename_additional_attributes"> <parameter key="Precipitations-7" value="Precipitations-8"/> <parameter key="Precipitations-6" value="Precipitations-7"/> <parameter key="Precipitations-5" value="Precipitations-6"/> <parameter key="Precipitations-4" value="Precipitations-5"/> <parameter key="Precipitations-3" value="Precipitations-4"/> <parameter key="Precipitations-2" value="Precipitations-3"/> <parameter key="Precipitations-1" value="Precipitations-2"/> <parameter key="Precipitations-0" value="Precipitations-1"/> <parameter key="prediction(label)" value="Precipitations-0"/> </list> </operator> <operator activated="true" class="remember" compatibility="8.1.000" expanded="true" height="68" name="Remember (2)" width="90" x="447" y="289"> <parameter key="name" value="data"/> </operator> <connect from_port="input 1" to_op="Apply Model" to_port="model"/> <connect from_op="Recall" from_port="result" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_port="output 1"/> <connect from_op="Multiply" from_port="output 2" to_op="Materialize Data (2)" to_port="example set input"/> <connect from_op="Materialize Data (2)" from_port="example set output" to_op="Increase Date (2)" to_port="example set input"/> <connect from_op="Increase Date (2)" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Select Attributes (3)" to_port="example set input"/> <connect from_op="Select Attributes (3)" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Remember (2)" to_port="store"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="8.1.000" expanded="true" height="82" name="Append" width="90" x="1653" y="34"/> <connect from_op="Read Excel" from_port="output" to_op="Set Predictions_Params" to_port="in 1"/> <connect from_op="Set Predictions_Params" from_port="out 1" to_op="Split" to_port="example set input"/> <connect from_op="Split" from_port="example set output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_op="Nominal to Date" to_port="example set input"/> <connect from_op="Nominal to Date" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Windowing for Training" to_port="example set input"/> <connect from_op="Windowing for Training" from_port="example set output" to_op="Deep Learning" to_port="training set"/> <connect from_op="Windowing for Training" from_port="original" to_op="Windowing for Application" to_port="example set input"/> <connect from_op="Deep Learning" from_port="model" to_op="Loop" to_port="input 1"/> <connect from_op="Windowing for Application" from_port="example set output" to_op="Extract Example Count" to_port="example set"/> <connect from_op="Extract Example Count" from_port="example set" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Remember" to_port="store"/> <connect from_op="Loop" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
2. The parameters used in this process are (parameters you can set) :
- Window size = 10 years
- Horizon = 1 year
- Prediction Future Years = 7 years
3. I used a Deep Learning model, but you can try other models to improve the accuracy of your predictions.
4. This process contains pre-processing on the format of the date (for example 1979-1980 ==> 1979 , 1980-1981 ==> 1980, etc.).
5. You can find the Excel file I builded from you data by following this link :
https://drive.google.com/open?id=1hiq6L4zWI24E086Icq2jBcGkSHOARsup
I hope it helps,
hello again dear @lionelderkrikor
thank you very much to the solution
I know you gave me the solution but I am ashamed to say that I don't know how to apply it and I'am illiterate in RapidMiner I spend all the week to understand but I failed and I don't know how I can success my project graduation.
regards ;
oussama .
Hi @lionelderkrikor,
I try to import your XML Process to lean whats your solution, but with RM 8.1.000 (Free) and get a lot of warnings.
What is to do, to get it run inside RM 8.1.000 (Free)
Thanks!
Thomas
Hi @thomas_wiedmann,
you need to install value series extension. It's available in market place.
Best,
Martin
Hi @mschmitz,
thanks. I will checked this.
BTW I wanted to "click on like" for your solution, but it has no effect. Sorry.
After get this extention from marketplace, everything work well.A least one question: I have no idea why Date contain "Dec 28, yyyy" now in result. Why "Dec 28"?
Thanks !
Hi Thomas,
Why "Dec 28"?
It's a good question and I will make a confession : I don't know why......
However good, in the nominal to date operator, I set "date format" as YYYY.
Or maybe in the Loop - > Increase date / Generates attributes operator when :
Year = date_add(Year, 1, DATE_UNIT_YEAR)
RapidMiner "forces" Year attribute to this format and value of "Dec 28"....
Best regards,
@lionelderkrikor and @thomas_wiedmann I've encountered that issue before in a similar process and if I remember correctly it had to do with how the date-time was being intrepreted in the loop. I fixed it but I don't remember how I did it.
oh the Dec 28 is a RapidMiner easter egg - that's @IngoRM's birthday. :smileyvery-happy:
Sorry couldn't resist.
Scott
Here some elements to better understand the process :
At the beginning of the process, we define the following parameters :
- Window size : determine how many "attributes" are created for the cross -sectionnal data. Each row of the original time series
within the window width will become a new attribute. In our case, w = 10 (years)
- Horizon : Determine how far out to make the forecast. In our case, h = 1 (year).
Our window size = 10 and horizon = 1, so the 11th row of the original time series becomes the first sample for the "label" variable.
This figure shows the original data and the transformed output from the windowing process and describes the transformation details.
The main point is that for the window selected and shown in the box, the target value is the value of Jan 1, 1989.
When training, the model using this data, the attributes named Precipitations-9 through Precipitations-0 form the "independent variables".
Then, the trained model is applied to generate forecast.
I hope you understand better the "general philosophy" of this process.
Moreover I suggest you to set a Breakpoint After on each operator (via right-clicking on an operator), to better understand
the transformation of data step by step.
@Thomas_Ott, @thomas_wiedmann
After trying several far fetched methods, I just add a Generate Attributes operator at the end of the process to convert
the date attribute to string. Now only the year is displayed.
Here the process :
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.000"> <context> <input/> <output/> <macros> <macro> <key>futureMonths</key> <value>15</value> </macro> <macro> <key>horizon</key> <value>1</value> </macro> <macro> <key>windowSize</key> <value>6</value> </macro> </macros> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="8.1.000" expanded="true" height="68" name="Read Excel" width="90" x="45" y="85"> <parameter key="excel_file" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\Tests_Rapidminer\Precipitations_forecast\Precipitations_forecast.xlsx"/> <parameter key="imported_cell_range" value="A1:B33"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="Year.true.polynominal.attribute"/> <parameter key="1" value="Precipitations.true.numeric.attribute"/> </list> </operator> <operator activated="true" class="subprocess" compatibility="8.1.000" expanded="true" height="82" name="Set Predictions_Params" width="90" x="179" y="85"> <process expanded="true"> <operator activated="true" class="set_macro" compatibility="8.1.000" expanded="true" height="82" name="Set Window_Size" width="90" x="45" y="34"> <parameter key="macro" value="WindowSize"/> <parameter key="value" value="10"/> </operator> <operator activated="true" class="set_macro" compatibility="8.1.000" expanded="true" height="82" name="Set Horizon" width="90" x="179" y="34"> <parameter key="macro" value="horizon"/> <parameter key="value" value="1"/> </operator> <operator activated="true" class="set_macro" compatibility="8.1.000" expanded="true" height="82" name="Set Future_Years" width="90" x="313" y="34"> <parameter key="macro" value="futureYears"/> <parameter key="value" value="7"/> </operator> <connect from_port="in 1" to_op="Set Window_Size" to_port="through 1"/> <connect from_op="Set Window_Size" from_port="through 1" to_op="Set Horizon" to_port="through 1"/> <connect from_op="Set Horizon" from_port="through 1" to_op="Set Future_Years" to_port="through 1"/> <connect from_op="Set Future_Years" from_port="through 1" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="split" compatibility="8.1.000" expanded="true" height="82" name="Split" width="90" x="313" y="85"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Year"/> <parameter key="split_pattern" value="-"/> </operator> <operator activated="true" class="rename" compatibility="8.1.000" expanded="true" height="82" name="Rename (2)" width="90" x="447" y="85"> <parameter key="old_name" value="Year_1"/> <parameter key="new_name" value="Year"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="nominal_to_date" compatibility="8.1.000" expanded="true" height="82" name="Nominal to Date" width="90" x="581" y="85"> <parameter key="attribute_name" value="Year"/> <parameter key="date_format" value="YYYY"/> </operator> <operator activated="true" class="set_role" compatibility="5.3.013" expanded="true" height="82" name="Set Role" width="90" x="715" y="85"> <parameter key="attribute_name" value="Year"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="select_attributes" compatibility="8.1.000" expanded="true" height="82" name="Select Attributes" width="90" x="849" y="85"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Precipitations"/> </operator> <operator activated="true" class="filter_examples" compatibility="6.4.000" expanded="true" height="103" name="Filter Examples" width="90" x="983" y="85"> <parameter key="condition_class" value="no_missing_attributes"/> <list key="filters_list"/> </operator> <operator activated="true" class="series:windowing" compatibility="5.2.000" expanded="true" height="82" name="Windowing for Training" width="90" x="1117" y="85"> <parameter key="window_size" value="%{WindowSize}"/> <parameter key="create_label" value="true"/> <parameter key="label_attribute" value="Precipitations"/> <parameter key="horizon" value="%{horizon}"/> </operator> <operator activated="true" class="h2o:deep_learning" compatibility="7.6.001" expanded="true" height="82" name="Deep Learning" width="90" x="1318" y="34"> <enumeration key="hidden_layer_sizes"> <parameter key="hidden_layer_sizes" value="50"/> <parameter key="hidden_layer_sizes" value="50"/> </enumeration> <enumeration key="hidden_dropout_ratios"/> <list key="expert_parameters"/> <list key="expert_parameters_"/> </operator> <operator activated="true" class="series:windowing" compatibility="5.2.000" expanded="true" height="82" name="Windowing for Application" width="90" x="1318" y="136"> <parameter key="window_size" value="%{WindowSize}"/> <parameter key="label_attribute" value="inputYt"/> </operator> <operator activated="true" class="extract_macro" compatibility="8.1.000" expanded="true" height="68" name="Extract Example Count" width="90" x="1519" y="136"> <parameter key="macro" value="exampleCount"/> <list key="additional_macros"/> </operator> <operator activated="true" class="filter_example_range" compatibility="8.1.000" expanded="true" height="82" name="Filter Example Range" width="90" x="1653" y="136"> <parameter key="first_example" value="%{exampleCount}"/> <parameter key="last_example" value="%{exampleCount}"/> </operator> <operator activated="true" class="remember" compatibility="8.1.000" expanded="true" height="68" name="Remember" width="90" x="1787" y="136"> <parameter key="name" value="data"/> </operator> <operator activated="true" class="loop" compatibility="8.1.000" expanded="true" height="82" name="Loop" width="90" x="1452" y="34"> <parameter key="iterations" value="%{futureYears}"/> <process expanded="true"> <operator activated="true" class="recall" compatibility="8.1.000" expanded="true" height="68" name="Recall" width="90" x="45" y="136"> <parameter key="name" value="data"/> </operator> <operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="82" name="Apply Model" width="90" x="179" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="multiply" compatibility="8.1.000" expanded="true" height="103" name="Multiply" width="90" x="447" y="30"/> <operator activated="true" class="materialize_data" compatibility="8.1.000" expanded="true" height="82" name="Materialize Data (2)" width="90" x="179" y="136"/> <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="82" name="Increase Date (2)" width="90" x="380" y="136"> <list key="function_descriptions"> <parameter key="Year" value="date_add(Year, 1, DATE_UNIT_YEAR)"/> </list> </operator> <operator activated="true" class="set_role" compatibility="5.3.013" expanded="true" height="82" name="Set Role (2)" width="90" x="715" y="187"> <parameter key="attribute_name" value="prediction(label)"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="select_attributes" compatibility="8.1.000" expanded="true" height="82" name="Select Attributes (3)" width="90" x="179" y="289"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Precipitations-9"/> <parameter key="invert_selection" value="true"/> </operator> <operator activated="true" class="rename" compatibility="8.1.000" expanded="true" height="82" name="Rename" width="90" x="313" y="289"> <parameter key="old_name" value="Precipitations-8"/> <parameter key="new_name" value="Precipitations-9"/> <list key="rename_additional_attributes"> <parameter key="Precipitations-7" value="Precipitations-8"/> <parameter key="Precipitations-6" value="Precipitations-7"/> <parameter key="Precipitations-5" value="Precipitations-6"/> <parameter key="Precipitations-4" value="Precipitations-5"/> <parameter key="Precipitations-3" value="Precipitations-4"/> <parameter key="Precipitations-2" value="Precipitations-3"/> <parameter key="Precipitations-1" value="Precipitations-2"/> <parameter key="Precipitations-0" value="Precipitations-1"/> <parameter key="prediction(label)" value="Precipitations-0"/> </list> </operator> <operator activated="true" class="remember" compatibility="8.1.000" expanded="true" height="68" name="Remember (2)" width="90" x="447" y="289"> <parameter key="name" value="data"/> </operator> <connect from_port="input 1" to_op="Apply Model" to_port="model"/> <connect from_op="Recall" from_port="result" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_port="output 1"/> <connect from_op="Multiply" from_port="output 2" to_op="Materialize Data (2)" to_port="example set input"/> <connect from_op="Materialize Data (2)" from_port="example set output" to_op="Increase Date (2)" to_port="example set input"/> <connect from_op="Increase Date (2)" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Select Attributes (3)" to_port="example set input"/> <connect from_op="Select Attributes (3)" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Remember (2)" to_port="store"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="8.1.000" expanded="true" height="82" name="Append" width="90" x="1586" y="34"/> <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="82" name="Format Date (3)" width="90" x="1720" y="34"> <list key="function_descriptions"> <parameter key="Year" value="date_str_custom(Year,"yyyy")"/> </list> </operator> <connect from_op="Read Excel" from_port="output" to_op="Set Predictions_Params" to_port="in 1"/> <connect from_op="Set Predictions_Params" from_port="out 1" to_op="Split" to_port="example set input"/> <connect from_op="Split" from_port="example set output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_op="Nominal to Date" to_port="example set input"/> <connect from_op="Nominal to Date" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Windowing for Training" to_port="example set input"/> <connect from_op="Windowing for Training" from_port="example set output" to_op="Deep Learning" to_port="training set"/> <connect from_op="Windowing for Training" from_port="original" to_op="Windowing for Application" to_port="example set input"/> <connect from_op="Deep Learning" from_port="model" to_op="Loop" to_port="input 1"/> <connect from_op="Windowing for Application" from_port="example set output" to_op="Extract Example Count" to_port="example set"/> <connect from_op="Extract Example Count" from_port="example set" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Remember" to_port="store"/> <connect from_op="Loop" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_op="Format Date (3)" to_port="example set input"/> <connect from_op="Format Date (3)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
@lionelderkrikor
True, work fine..!
