I am trying to generate a simple correlation matrix - the input is nominal data which has been converted to binominal (I tried all parameter settings). The process fails at the input or immediate processing of the correlation matrix. Any suggestions on what this error means?
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.1.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="8.1.000" expanded="true" height="68" name="Retrieve 4 - MN Excav Data - Digs wDefects - Data Set" width="90" x="112" y="85">
<parameter key="repository_entry" value="../02 - Excavation Data/4 - MN Excav Data - Digs wDefects - Data Set"/>
<operator activated="true" class="retrieve" compatibility="8.1.000" expanded="true" height="68" name="Retrieve 20 - EC Weights" width="90" x="112" y="238">
<parameter key="repository_entry" value="20 - EC Weights"/>
<operator activated="true" class="select_by_weights" compatibility="8.1.000" expanded="true" height="103" name="Select by Weights" width="90" x="313" y="187"/>
<operator activated="true" class="nominal_to_binominal" compatibility="8.1.000" expanded="true" height="103" name="Nominal to Binominal" width="90" x="514" y="187">
<parameter key="transform_binominal" value="true"/>
<parameter key="use_underscore_in_name" value="true"/>
<operator activated="true" class="concurrency:correlation_matrix" compatibility="8.1.000" expanded="true" height="103" name="Correlation Matrix" width="90" x="715" y="187">
<connect from_op="Retrieve 4 - MN Excav Data - Digs wDefects - Data Set" from_port="output" to_op="Select by Weights" to_port="example set input"/>
<connect from_op="Retrieve 20 - EC Weights" from_port="output" to_op="Select by Weights" to_port="weights"/>
<connect from_op="Select by Weights" from_port="example set output" to_op="Nominal to Binominal" to_port="example set input"/>
<connect from_op="Nominal to Binominal" from_port="example set output" to_op="Correlation Matrix" to_port="example set"/>
<connect from_op="Correlation Matrix" from_port="example set" to_port="result 1"/>
<connect from_op="Correlation Matrix" from_port="matrix" to_port="result 2"/>
<description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="400" y="586">Type your comment</description>
</process>
</process>
