I got server error 500 occurred when I log in
Hello, I got A server error 500 occurred: . The error has been recorded.
when I login or click home on web interface
I try to restart server,
re-install server, java and mysql-server but error has not been solve
OS : Ububtu 16.04
Java :
javac 1.8.0_161
java version "1.8.0_161"
MySQL :
mysql Ver 14.14 Distrib 5.7.21, for Linux (x86_64) using EditLine wrapper
RMServer : 8.1.0 and mysql connector java v.5.1.31
Hi @suu_f,
Your would you please share the server.log where we can see the full startup of RapidMiner Server?
Best,
Edin
0 -
Hi @suu_f,
sorry for the delay. Your log file shows multiple errors. Let's try and tackle them one by one.
It seems as if the host and port you provided during installation cannot be accessed.
Can you please recheck that ports 88 and 5672 are accessible and try a fresh installation?
On which host do you want to install RapidMiner Server - localhost?
Adding service endpoint metadata: id=RepositoryService address=http://jbossws.undefined.host:88/api/soap/RepositoryService
ServerService Thread Pool -- 75) java.io.IOException: Transport Connector could not be registered in JMX: java.io.IOException: Failed to bind to server socket: tcp://10.11.30.25:5672 due to: java.net.BindException: Cannot assign requested address (Bind failed)
Best,
Edin
1
