🎉Community Raffle - Win $25
Join and Win
How to load dataset from Java application to a Rapidminer process?
User: "nom1010"
New Altair Community Member
Updated by Jocelyn
This is my rapidminer process, and I can load it to my Java application, and run it, after that print out the result, what I see in Rapidminer Studio. My problem is, I don't know how can I add a dataset from the app to the loaded project, instead of using retrieve box, before set the role?
1 - 1 of 11
    User: "Thomas_Ott"
    Accepted Answer
    Not sure on where all your data is coming from but if you want to load multiple data sets you could use a Read CSV or Read XLS operator in conjuction with a Loop Files or Loop operator, instead of the Retrieve operator. The Retrieve operator is a RapidMiner optimized data repository, but the data can come from CSV, databases, Hadoop, etc. You don't really need to Load Data > Store in Repository > Retrieve Data > Process, you can just Load Data > Process
