Hi
this is probably a very simple thing to do in RapiMiner, but I can not find a way how to do it:
can someone please show me how to set the filename of the loaded data as an attribute ?
Much appreciated !
Oliver
Hi Oliver,
if you read Files with Read Excel or Read CSV or even with a Read Database they have an annotation called source which includes the path. That means you do not forget the original location.
You can add this annotation as a attribute to your table if you want to. Attached is a process demonstrating it.
Best,
Martin
<?xml version="1.0" encoding="UTF-8"?><process version="8.0.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="8.0.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_csv" compatibility="8.0.001" expanded="true" height="68" name="Read CSV" width="90" x="112" y="136"> <parameter key="csv_file" value="C:\Users\Martin\Desktop\0_Hotel_Review_Data.csv"/> <parameter key="column_separators" value=","/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <parameter key="encoding" value="windows-1252"/> <list key="data_set_meta_data_information"> <parameter key="0" value="Text.true.polynominal.attribute"/> <parameter key="1" value="Rating.true.real.attribute"/> <parameter key="2" value="ReviewId.true.real.attribute"/> </list> </operator> <operator activated="true" class="annotations_to_data" compatibility="8.0.001" expanded="true" height="82" name="Annotations to Data" width="90" x="246" y="136"/> <operator activated="true" class="filter_examples" compatibility="8.0.001" expanded="true" height="103" name="Filter Examples" width="90" x="380" y="34"> <list key="filters_list"> <parameter key="filters_entry_key" value="annotation.equals.Source"/> </list> </operator> <operator activated="true" class="extract_macro" compatibility="8.0.001" expanded="true" height="68" name="Extract Macro" width="90" x="581" y="34"> <parameter key="macro" value="Source"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="value"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" class="delay" compatibility="8.0.001" expanded="true" height="103" name="Delay" width="90" x="715" y="85"> <parameter key="delay_amount" value="0"/> <description align="center" color="transparent" colored="false" width="126">Only to ensure execution order</description> </operator> <operator activated="true" class="generate_attributes" compatibility="8.0.001" expanded="true" height="82" name="Generate Attributes" width="90" x="849" y="136"> <list key="function_descriptions"> <parameter key="Source" value="%{source}"/> </list> </operator> <connect from_op="Read CSV" from_port="output" to_op="Annotations to Data" to_port="object"/> <connect from_op="Annotations to Data" from_port="annotations" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Annotations to Data" from_port="object through" to_op="Delay" to_port="through 2"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Delay" to_port="through 1"/> <connect from_op="Delay" from_port="through 1" to_port="result 1"/> <connect from_op="Delay" from_port="through 2" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
Thanks!
