What is the TCL Command to 'get nodes of elements' to which 'hexa node is projeted'?
Please see the image
There is no direct command I think.
did you search on script exchange?
tinh, I have searched it but it went in vain. Please help me to do this.
use hwat package but you have to put your shell comps into an assembly, named ShellComps for example.
code
package require hwat *createmarkpanel nodes 1 'Select a node of hexa element:' set NodeId [hm_getmark nodes 1] lassign [join [hm_nodevalue $NodeId]] x y z set AttachedShellElemId [::hwat::utils::GetClosestElement $x $y $z ShellComps] puts 'Attached shell element is $AttachedShellElemId'
Dear Tinh,
Please understand my requirement.
I have to get the IDs of nodes of shell element to which node of hexa is projected. See the image.
Your last code will give the selected node's ID which is not my requirement.
package require hwat *createmarkpanel nodes 1 'Select a node of hexa element:' set NodeId [hm_getmark nodes 1] lassign [join [hm_nodevalue $NodeId]] x y z set AttachedShellElemId [::hwat::utils::GetClosestElement $x $y $z ShellComps] *createmark nodes 1 'by element' $AttachedShellElemId puts 'Nodes: [hm_getmark nodes 1]'
Hi
add more above command
Dear Tinh, Please understand my requirement. I have to get the IDs of nodes of shell element to which node of hexa is projected. See the image. Your last code will give the selected node's ID which is not my requirement.
Once you got the element ID => you will get its nodes
What do you mean with 'give the selected node's ID'?
When I have tried your code, It is returning id of selected hexa node. In mean time I want to return node ids of element to which hexa node is projected.
I said, you have to put the shell comps into an assembly named ShellComps, did you do it?
and do not put hexa comp to that assembly
Thanks Tinh, for your kindly support
Hi Tinh,
Please see the image. I have marked two nodes in the image. If i select those nodes, opposite element is selected. That is, I am getting wrong selection.
My hexa height is 1.9.
One side is perfect, while opposite not. When I increase tolerance between two shell mesh(increase height of hexa) it works. Please help me to solve
I understand, it's because a node of lower element is closer to hexa node than nodes of the expected element
a strategy for you that, once you find the element, get it's component and temporary remove this component from assembly ShellComps, then search again for closest element.
you'll get upper and lower elements, and now you can compare normal distance from hexa node to these 2 elements, finally you get the closer one by compare 2 distance values.
After done, put again the component into assembly ShellComps if you continue search for other position
Can you write codes for above works?
Thanks Tinh. I am a beginner in coding. I am trying that. Meantime if you could, it will be fine
Please try it and tell us if you are stuck on somthing
I have Node id in $NodeID & element ids: $AttachedShellElemId2 and $AttachedShellElemId2. Now how to measure the normal distance. please help me.
package require hwat *createmarkpanel nodes 1 'Select a node of hexa element:' set NodeId [hm_getmark nodes 1] lassign [join [hm_nodevalue $NodeId]] x y z set AttachedShellElemId [::hwat::utils::GetClosestElement $x $y $z ShellComps] *createmark nodes 1 'by element' $AttachedShellElemId puts 'Nodes: [hm_getmark nodes 1]' set comid [hm_getvalue elems id=$AttachedShellElemId dataname=collector.id] set coname [hm_getvalue elems id=$AttachedShellElemId dataname=collector.name] puts $comid puts $coname
*createmark assemblies 2 'ShellComps' *createmark components 1 $coname *assemblyremovemark 2 components 1 *createmark components 2 $coname *assemblyaddmark 2 components 2 lassign [join [hm_nodevalue $NodeId]] x y z set AttachedShellElemId2 [::hwat::utils::GetClosestElement $x $y $z ShellComps] *createmark nodes 1 'by element' $AttachedShellElemId2 puts 'Nodes: [hm_getmark nodes 1]' set comid2 [hm_getvalue elems id=$AttachedShellElemId2 dataname=collector.id] set coname2 [hm_getvalue elems id=$AttachedShellElemId2 dataname=collector.name] puts $comid2 puts $coname2 *createmark assemblies 2 'ShellComps' *createmark components 1 $coname2 *assemblyremovemark 2 components 1 *createmark components 2 $coname2 *assemblyaddmark 2 components 2
with each shell element, you get one of its node for example NodeOfElem1, NodeOfElem2
with each shell element, you get its normal vector (using hm_getvalue elems id=$AttachedShellElemId dataname=normalx , normaly, normalz)
then you can calculate distance from the hexa node to each plane define by normal vector and NodeOfElem
But Tinh, I want to calculate normal distance.
what is the command to calculate distance from the hexa node to each plane define by normal vector and NodeOfElem
*createmarkpanel nodes 1 'Select a node of hexa:' set NodeOfHexa [hm_getmark nodes 1] set NodeXYZ [join [hm_nodevalue $NodeOfHexa]] set ShellElem1 [::hwat::utils::GetClosestElement {*}$NodeXYZ ShellComps] set CompIdOfElem1 [hm_getvalue elems id=$ShellElem1 dataname=collector.id]
set ShellElem2 [::hwat::utils::GetClosestElement {*}$NodeXYZ ShellComps] lassign [hm_nodelist $ShellElem1] NodeElem1 lassign [hm_nodelist $ShellElem2] NodeElem2 set N1x [hm_getvalue elems id=$ShellElem1 dataname=normalx] set N1y [hm_getvalue elems id=$ShellElem1 dataname=normaly] set N1z [hm_getvalue elems id=$ShellElem1 dataname=normalz] set N2x [hm_getvalue elems id=$ShellElem2 dataname=normalx] set N2y [hm_getvalue elems id=$ShellElem2 dataname=normaly] set N2z [hm_getvalue elems id=$ShellElem2 dataname=normalz] set Vector1 [::hwat::math::GetVector [join [hm_nodevalue $NodeElem1]] [join [hm_nodevalue $NodeOfHexa]]] set Vector2 [::hwat::math::GetVector [join [hm_nodevalue $NodeElem2]] [join [hm_nodevalue $NodeOfHexa]]] set CosA1 [hm_triplecos {*}$Vector1 $N1x $N1y $N1z]
set CosA2 [hm_triplecos {*}$Vector2 $N2x $N2y $N2z] puts $CosA1 puts $CosA2
But Tinh, I want to calculate normal distance. what is the command to calculate distance from the hexa node to each plane define by normal vector and NodeOfElem
It's just a vector operator
d = D*cos(a)
D = distance from hexa node to shell node
a = angle between shell normal and vector generated from shell node to hexa node
actually you just need to compare cos(a1) and cos(a2) (that is dot product / magnitude)
Deat Tinh, Now i am completely confused, please help me in remaining.
package require hwat *createmarkpanel nodes 1 'Select a node of hexa element:' set NodeId [hm_getmark nodes 1] lassign [join [hm_nodevalue $NodeId]] x y z set AttachedShellElemId [::hwat::utils::GetClosestElement $x $y $z ShellComps] *createmark nodes 1 'by element' $AttachedShellElemId set nide [hm_getmark nodes 1] set comid [hm_getvalue elems id=$AttachedShellElemId dataname=collector.id] set coname [hm_getvalue elems id=$AttachedShellElemId dataname=collector.name] puts $comid puts $coname set nod1 [lindex $nide 0] set nod2 [lindex $nide 1] set nod3 [lindex $nide 2]
*createmark assemblies 2 'ShellComps' *createmark components 1 $coname *assemblyremovemark 2 components 1 *createmark components 2 $coname *assemblyaddmark 2 components 2 lassign [join [hm_nodevalue $NodeId]] x y z set AttachedShellElemId2 [::hwat::utils::GetClosestElement $x $y $z ShellComps] *createmark nodes 1 'by element' $AttachedShellElemId2 set nide2 [hm_getmark nodes 1] set comid2 [hm_getvalue elems id=$AttachedShellElemId2 dataname=collector.id] set coname2 [hm_getvalue elems id=$AttachedShellElemId2 dataname=collector.name] puts $comid2 puts $coname2 set nod1 [lindex $nide2 0] set nod2 [lindex $nide2 1] set nod3 [lindex $nide2 2] *createmark assemblies 2 'ShellComps' *createmark components 1 $coname2 *assemblyremovemark 2 components 1 *createmark components 2 $coname2 *assemblyaddmark 2 components 2
To make it clearly and not be confused, you have to write some procs:
proc p_AddCompIDsToAssem {AssemName CompIDs} {
=> write commands to add CompIDs to assembly AssemName
proc p_RemoveCompIDsFromAssem {AssemName CompIDs} {
-> write commands to remove CompIDs
example you have 2 shell comps, ID 5 and 7, first -> add it in ShellComps
p_AddCompIDsToAssem ShellComps {5 7}
p_RemoveCompIDsFromAssem ShellComps $CompIdOfElem1
set N1y...
set N1z...
set N2x...
set N2y..
set N2z...
set CosA2 ...
=> compare 2 cosine value
p_AddCompIDsToAssem ShellComps $CompIdOfElem1
Thanks for your support. But I am facing a problem. Out of 8 nodes, 2 nodes are selecting wrong components using below code. please see the image also.
*createmarkpanel nodes 1 'Select a node of hexa:' set NodeOfHexa [hm_getmark nodes 1] set NodeXYZ [join [hm_nodevalue $NodeOfHexa]] set ShellElem1 [::hwat::utils::GetClosestElement {*}$NodeXYZ ShellComps] set CompIdOfElem1 [hm_getvalue elems id=$ShellElem1 dataname=collector.id] set coname1 [hm_getvalue elems id=$ShellElem1 dataname=collector.name]
*createmark assemblies 2 'ShellComps' *createmark components 1 $coname *assemblyremovemark 2 components 1 *createmark components 2 $coname *assemblyaddmark 2 components 2 set ShellElem2 [::hwat::utils::GetClosestElement {*}$NodeXYZ ShellComps] set coname2 [hm_getvalue elems id=$ShellElem2 dataname=collector.name] lassign [hm_nodelist $ShellElem1] NodeElem1 lassign [hm_nodelist $ShellElem2] NodeElem2 set N1x [hm_getvalue elems id=$ShellElem1 dataname=normalx] set N1y [hm_getvalue elems id=$ShellElem1 dataname=normaly] set N1z [hm_getvalue elems id=$ShellElem1 dataname=normalz] set N2x [hm_getvalue elems id=$ShellElem2 dataname=normalx] set N2y [hm_getvalue elems id=$ShellElem2 dataname=normaly] set N2z [hm_getvalue elems id=$ShellElem2 dataname=normalz] set Vector1 [::hwat::math::GetVector [join [hm_nodevalue $NodeElem1]] [join [hm_nodevalue $NodeOfHexa]]] set Vector2 [::hwat::math::GetVector [join [hm_nodevalue $NodeElem2]] [join [hm_nodevalue $NodeOfHexa]]] set CosA1 [hm_triplecos {*}$Vector1 $N1x $N1y $N1z] set CosA2 [hm_triplecos {*}$Vector2 $N2x $N2y $N2z] puts $CosA1 puts $CosA2
if {$CosA1 > $CosA2} {
*createmark assemblies 2 'ShellComps' *createmark components 1 all *assemblyremovemark 2 components 1 *createmark components 2 all *assemblyaddmark 2 components 2
*createmark assemblies 2 'coname' *createmark components 1 $coname1 *assemblyremovemark 2 components 1 *createmark components 2 $coname1 *assemblyaddmark 1 components 2 } elseif {$CosA1 < $CosA2} { *createmark assemblies 2 'coname' *createmark components 1 $coname2 *assemblyremovemark 2 components 1 *createmark components 2 $coname2 *assemblyaddmark 1 components 2 }
please write the 2 procs. I want to see them, they are key point of problem
I have duplicated few nodes(say 10 nodes). How to retrieve those 10 nodes and renumber with known IDs
Try
*createmark nodes 1 -1 -2 -3 -4 -5 -6 -7 -8 -9 -10
*renumber.....
