Hi,
use hwat package but you have to put your shell comps into an assembly, named ShellComps for example.
code
package require hwat *createmarkpanel nodes 1 'Select a node of hexa element:' set NodeId [hm_getmark nodes 1] lassign [join [hm_nodevalue $NodeId]] x y z set AttachedShellElemId [::hwat::utils::GetClosestElement $x $y $z ShellComps] puts 'Attached shell element is $AttachedShellElemId'
package require hwat *createmarkpanel nodes 1 'Select a node of hexa element:' set NodeId [hm_getmark nodes 1] lassign [join [hm_nodevalue $NodeId]] x y z set AttachedShellElemId [::hwat::utils::GetClosestElement $x $y $z ShellComps] *createmark nodes 1 'by element' $AttachedShellElemId puts 'Nodes: [hm_getmark nodes 1]'
Hi
add more above command
Dear Tinh,
Please understand my requirement.
I have to get the IDs of nodes of shell element to which node of hexa is projected. See the image.
Your last code will give the selected node's ID which is not my requirement.
Once you got the element ID => you will get its nodes
What do you mean with 'give the selected node's ID'?
I understand, it's because a node of lower element is closer to hexa node than nodes of the expected element
a strategy for you that, once you find the element, get it's component and temporary remove this component from assembly ShellComps, then search again for closest element.
you'll get upper and lower elements, and now you can compare normal distance from hexa node to these 2 elements, finally you get the closer one by compare 2 distance values.
After done, put again the component into assembly ShellComps if you continue search for other position
Can you write codes for above works?
Hi Tinh,
I have Node id in $NodeID & element ids: $AttachedShellElemId2 and $AttachedShellElemId2. Now how to measure the normal distance. please help me.
set comid [hm_getvalue elems id=$AttachedShellElemId dataname=collector.id]
set coname [hm_getvalue elems id=$AttachedShellElemId dataname=collector.name]
puts $comid
puts $coname
*createmark assemblies 2 'ShellComps'
*createmark components 1 $coname
*assemblyremovemark 2 components 1
*createmark components 2 $coname
*assemblyaddmark 2 components 2
set AttachedShellElemId2 [::hwat::utils::GetClosestElement $x $y $z ShellComps]
*createmark nodes 1 'by element' $AttachedShellElemId2
set comid2 [hm_getvalue elems id=$AttachedShellElemId2 dataname=collector.id]
set coname2 [hm_getvalue elems id=$AttachedShellElemId2 dataname=collector.name]
puts $comid2
puts $coname2
*createmark components 1 $coname2
*createmark components 2 $coname2
Hi,
with each shell element, you get one of its node for example NodeOfElem1, NodeOfElem2
with each shell element, you get its normal vector (using hm_getvalue elems id=$AttachedShellElemId dataname=normalx , normaly, normalz)
then you can calculate distance from the hexa node to each plane define by normal vector and NodeOfElem
But Tinh, I want to calculate normal distance.
what is the command to calculate distance from the hexa node to each plane define by normal vector and NodeOfElem
*createmarkpanel nodes 1 'Select a node of hexa:'
set NodeOfHexa [hm_getmark nodes 1]
set NodeXYZ [join [hm_nodevalue $NodeOfHexa]]
set ShellElem1 [::hwat::utils::GetClosestElement {*}$NodeXYZ ShellComps]
set CompIdOfElem1 [hm_getvalue elems id=$ShellElem1 dataname=collector.id]
set ShellElem2 [::hwat::utils::GetClosestElement {*}$NodeXYZ ShellComps]
lassign [hm_nodelist $ShellElem1] NodeElem1
lassign [hm_nodelist $ShellElem2] NodeElem2
set N1x [hm_getvalue elems id=$ShellElem1 dataname=normalx]
set N1y [hm_getvalue elems id=$ShellElem1 dataname=normaly]
set N1z [hm_getvalue elems id=$ShellElem1 dataname=normalz]
set N2x [hm_getvalue elems id=$ShellElem2 dataname=normalx]
set N2y [hm_getvalue elems id=$ShellElem2 dataname=normaly]
set N2z [hm_getvalue elems id=$ShellElem2 dataname=normalz]
set Vector1 [::hwat::math::GetVector [join [hm_nodevalue $NodeElem1]] [join [hm_nodevalue $NodeOfHexa]]]
set Vector2 [::hwat::math::GetVector [join [hm_nodevalue $NodeElem2]] [join [hm_nodevalue $NodeOfHexa]]]
set CosA1 [hm_triplecos {*}$Vector1 $N1x $N1y $N1z]
set CosA2 [hm_triplecos {*}$Vector2 $N2x $N2y $N2z]
puts $CosA1
puts $CosA2
It's just a vector operator
d = D*cos(a)
D = distance from hexa node to shell node
a = angle between shell normal and vector generated from shell node to hexa node
actually you just need to compare cos(a1) and cos(a2) (that is dot product / magnitude)
Deat Tinh, Now i am completely confused, please help me in remaining.
set nide [hm_getmark nodes 1]
puts $comid
puts $coname
set nod1 [lindex $nide 0]
set nod2 [lindex $nide 1]
set nod3 [lindex $nide 2]
set nide2 [hm_getmark nodes 1]
puts $comid2
puts $coname2
set nod1 [lindex $nide2 0]
set nod2 [lindex $nide2 1]
set nod3 [lindex $nide2 2]
Hi,
To make it clearly and not be confused, you have to write some procs:
proc p_AddCompIDsToAssem {AssemName CompIDs} {
=> write commands to add CompIDs to assembly AssemName
proc p_RemoveCompIDsFromAssem {AssemName CompIDs} {
-> write commands to remove CompIDs
example you have 2 shell comps, ID 5 and 7, first -> add it in ShellComps
p_AddCompIDsToAssem ShellComps {5 7}
p_RemoveCompIDsFromAssem ShellComps $CompIdOfElem1
set N1y...
set N1z...
set N2x...
set N2y..
set N2z...
set CosA2 ...
=> compare 2 cosine value
p_AddCompIDsToAssem ShellComps $CompIdOfElem1
Dear Tinh,
Thanks for your support. But I am facing a problem. Out of 8 nodes, 2 nodes are selecting wrong components using below code. please see the image also.
set coname1 [hm_getvalue elems id=$ShellElem1 dataname=collector.name]
set coname2 [hm_getvalue elems id=$ShellElem2 dataname=collector.name]
puts $CosA1
puts $CosA2
if {$CosA1 > $CosA2} {
*createmark components 1 all
*createmark components 2 all
*createmark assemblies 2 'coname'
*createmark components 1 $coname1
*createmark components 2 $coname1
*assemblyaddmark 1 components 2
} elseif {$CosA1 < $CosA2} {
There is no direct command I think.
did you search on script exchange?
