Altair RISE
Nominate Yourself Now!
What is the TCL Command to "get nodes of elements" to which "hexa node is projeted"?
User: "Jouher_20929"
Altair Community Member
Updated by Jouher_20929
What is the TCL Command to 'get nodes of elements' to which 'hexa node is projeted'?
1 - 24 of 241
    User: "tinh"
    Updated by tinh
    There is no direct command I think.
    did you search on script exchange?
    OP
    tinh, I have searched it but  it went in vain. Please help me to do this.
    User: "tinh"
    Updated by tinh
    Hi,
    use hwat package but you have to put your shell comps into an assembly, named ShellComps for example.
    code
     package require hwat   *createmarkpanel nodes 1 'Select a node of hexa element:'   set NodeId [hm_getmark nodes 1]   lassign [join [hm_nodevalue $NodeId]] x y z   set AttachedShellElemId [::hwat::utils::GetClosestElement $x $y $z ShellComps]   puts 'Attached shell element is $AttachedShellElemId'
    OP
    Dear Tinh,
    Please understand my requirement.
    I have to get the IDs of nodes of shell element to which node of hexa is projected. See the image.
    Your last code will give the selected node's ID which is not my requirement.
    User: "tinh"
    Updated by tinh
     package require hwat   *createmarkpanel nodes 1 'Select a node of hexa element:'   set NodeId [hm_getmark nodes 1]   lassign [join [hm_nodevalue $NodeId]] x y z   set AttachedShellElemId [::hwat::utils::GetClosestElement $x $y $z ShellComps]   *createmark nodes 1 'by element' $AttachedShellElemId   puts 'Nodes: [hm_getmark nodes 1]'
    Hi
    add more above command
    User: "tinh"
    Updated by tinh
    Dear Tinh,
    Once you got the element ID => you will get its nodes
    What do you mean with 'give the selected node's ID'?
    OP
    When I have tried your code, It is returning id of selected hexa node. In mean time  I want to return node ids of element to which hexa node is projected.
    User: "tinh"
    Updated by tinh
    I said, you have to put the shell comps into an assembly named ShellComps, did you do it?
    and do not put hexa comp to that assembly
    OP
    Thanks Tinh, for your kindly support
    OP
    Hi Tinh,
    Please see the image. I have marked two nodes in the image. If i select those nodes, opposite element is selected. That is, I am getting wrong selection.
    OP
    One side is perfect, while opposite not. When I increase tolerance between two shell mesh(increase height of hexa) it works. Please help me to solve
    User: "tinh"
    Updated by tinh
    I understand, it's because a node of lower element is closer to hexa node than nodes of the expected element
    a strategy for you that, once you find the element, get it's component and temporary remove this component from assembly ShellComps, then search again for closest element.
    you'll get upper and lower elements, and now you can compare normal distance from hexa node to these 2 elements, finally you get the closer one by compare 2 distance values.
    After done, put again the component into assembly ShellComps if you continue search for other position
    Can you write codes for above works?
    OP
    Thanks Tinh. I am a beginner in coding. I am trying that. Meantime if you could, it will be fine
    User: "tinh"
    Updated by tinh
    Please try it and tell us if you are stuck on somthing
    OP
    Hi Tinh,
    I have Node id in $NodeID & element ids: $AttachedShellElemId2  and  $AttachedShellElemId2. Now how to measure the normal distance. please help me.
        set comid [hm_getvalue elems id=$AttachedShellElemId dataname=collector.id]
        set coname [hm_getvalue elems id=$AttachedShellElemId dataname=collector.name]
        puts $comid
        puts $coname
      *createmark assemblies 2 'ShellComps'
      *createmark components 1 $coname
      *assemblyremovemark 2 components 1
      *createmark components 2 $coname
      *assemblyaddmark 2 components 2
          set AttachedShellElemId2 [::hwat::utils::GetClosestElement $x $y $z ShellComps]
          *createmark nodes 1 'by element' $AttachedShellElemId2
          set comid2 [hm_getvalue elems id=$AttachedShellElemId2 dataname=collector.id]
          set coname2 [hm_getvalue elems id=$AttachedShellElemId2 dataname=collector.name]
          puts $comid2
          puts $coname2
        *createmark components 1 $coname2
        *createmark components 2 $coname2
    User: "tinh"
    Updated by tinh
    Hi,
    with each shell element, you get one of its node for example NodeOfElem1, NodeOfElem2
    with each shell element, you get its normal vector (using hm_getvalue elems id=$AttachedShellElemId dataname=normalx , normaly, normalz)
    then you can calculate distance from the hexa node to each plane define by normal vector and NodeOfElem
    OP
    But Tinh, I want to calculate normal distance.
    what is the command to calculate distance from the hexa node to each plane define by normal vector and NodeOfElem
    *createmarkpanel nodes 1 'Select a node of hexa:'
    set NodeOfHexa [hm_getmark nodes 1]
    set NodeXYZ [join [hm_nodevalue $NodeOfHexa]]
    set ShellElem1 [::hwat::utils::GetClosestElement {*}$NodeXYZ ShellComps]
    set CompIdOfElem1 [hm_getvalue elems id=$ShellElem1 dataname=collector.id]
    set ShellElem2 [::hwat::utils::GetClosestElement {*}$NodeXYZ ShellComps]
    lassign [hm_nodelist $ShellElem1] NodeElem1
    lassign [hm_nodelist $ShellElem2] NodeElem2
    set N1x [hm_getvalue elems id=$ShellElem1 dataname=normalx]
    set N1y [hm_getvalue elems id=$ShellElem1 dataname=normaly]
    set N1z [hm_getvalue elems id=$ShellElem1 dataname=normalz]
    set N2x [hm_getvalue elems id=$ShellElem2 dataname=normalx]
    set N2y [hm_getvalue elems id=$ShellElem2 dataname=normaly]
    set N2z [hm_getvalue elems id=$ShellElem2 dataname=normalz]
    set Vector1 [::hwat::math::GetVector [join [hm_nodevalue $NodeElem1]] [join [hm_nodevalue $NodeOfHexa]]]
    set Vector2 [::hwat::math::GetVector [join [hm_nodevalue $NodeElem2]] [join [hm_nodevalue $NodeOfHexa]]]
    set CosA1 [hm_triplecos {*}$Vector1 $N1x $N1y $N1z]
    set CosA2 [hm_triplecos {*}$Vector2 $N2x $N2y $N2z]
    puts $CosA1
    puts $CosA2
    User: "tinh"
    Updated by tinh
    It's just a vector operator
    d = D*cos(a)
    D = distance from hexa node to shell node
    a = angle between shell normal and vector generated from shell node to hexa node
    actually you just need to compare cos(a1) and cos(a2) (that is dot product / magnitude)
    OP
    Deat Tinh, Now i am completely confused, please help me in remaining.
      set nide [hm_getmark nodes 1]
        puts $comid
        puts $coname
        set nod1 [lindex $nide 0]
        set nod2 [lindex $nide 1]
    set nod3 [lindex $nide 2]
      set nide2 [hm_getmark nodes 1]
          puts $comid2
          puts $coname2
          set nod1 [lindex $nide2 0]
          set nod2 [lindex $nide2 1]
    set nod3 [lindex $nide2 2]
    User: "tinh"
    Updated by tinh
    Hi,
    To make it clearly and not be confused, you have to write some procs:
    proc p_AddCompIDsToAssem {AssemName CompIDs} {
            => write commands to add CompIDs to assembly AssemName
    proc p_RemoveCompIDsFromAssem {AssemName CompIDs} {
          -> write commands to remove CompIDs
    example you have 2 shell comps, ID 5 and 7, first -> add it in ShellComps
    p_AddCompIDsToAssem ShellComps {5 7}
    p_RemoveCompIDsFromAssem ShellComps $CompIdOfElem1
    set N1y...
    set N1z...
    set N2x...
    set N2y..
    set N2z...
    set CosA2 ...
    => compare 2 cosine value
    p_AddCompIDsToAssem ShellComps $CompIdOfElem1
    OP
    Dear Tinh,
    Thanks for your support. But I am facing a problem. Out of 8 nodes, 2 nodes are selecting wrong components using below code. please see the image also.
      set coname1 [hm_getvalue elems id=$ShellElem1 dataname=collector.name]
    set coname2 [hm_getvalue elems id=$ShellElem2 dataname=collector.name]
    puts $CosA1
    puts $CosA2
    if {$CosA1 > $CosA2} {
      *createmark components 1 all
      *createmark components 2 all
    *createmark assemblies 2 'coname'
    *createmark components 1 $coname1
    *createmark components 2 $coname1
    *assemblyaddmark 1 components 2
    } elseif {$CosA1 < $CosA2} {
    User: "tinh"
    Updated by tinh
    please write the 2 procs. I want to see them, they are key point of problem
    User: "Manoj Yandra"
    Updated by Manoj Yandra
    I have duplicated few nodes(say 10 nodes). How to retrieve those 10 nodes and renumber with known IDs
    User: "tinh"
    Updated by tinh
    Try
    *createmark nodes 1 -1 -2 -3 -4 -5 -6 -7 -8 -9 -10
    *renumber.....
