I created 2 processes including a decision tree model from the "Golf" dataset.
1. First a classic DT model :
In this case, for the attribute weights, i get :
Here the process :
<?xml version="1.0" encoding="UTF-8"?><process version="8.0.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.0.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="8.0.001" expanded="true" height="68" name="Retrieve Golf" width="90" x="45" y="34">
<parameter key="repository_entry" value="//Samples/data/Golf"/>
<operator activated="true" class="concurrency:parallel_decision_tree" compatibility="8.0.001" expanded="true" height="103" name="Decision Tree" width="90" x="313" y="34"/>
<connect from_op="Retrieve Golf" from_port="output" to_op="Decision Tree" to_port="training set"/>
<connect from_op="Decision Tree" from_port="model" to_port="result 1"/>
<connect from_op="Decision Tree" from_port="exampleSet" to_port="result 2"/>
<connect from_op="Decision Tree" from_port="weights" to_port="result 3"/>
</process>
</process>
2. A DT model with a cross validation :
Here the process :
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="concurrency:cross_validation" compatibility="8.0.001" expanded="true" height="145" name="Cross Validation" width="90" x="313" y="34">
<operator activated="true" class="concurrency:parallel_decision_tree" compatibility="8.0.001" expanded="true" height="103" name="Decision Tree" width="90" x="179" y="34"/>
<operator activated="true" class="weights_to_data" compatibility="8.0.001" expanded="true" height="68" name="Weights to Data" width="90" x="313" y="85"/>
<operator activated="true" class="remember" compatibility="8.0.001" expanded="true" height="68" name="Remember" width="90" x="447" y="85">
<parameter key="name" value="DT_weight"/>
<connect from_port="training set" to_op="Decision Tree" to_port="training set"/>
<connect from_op="Decision Tree" from_port="model" to_port="model"/>
<connect from_op="Decision Tree" from_port="weights" to_op="Weights to Data" to_port="attribute weights"/>
<connect from_op="Weights to Data" from_port="example set" to_op="Remember" to_port="store"/>
<portSpacing port="source_training set" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="8.0.001" expanded="true" height="82" name="Apply Model" width="90" x="45" y="34">
<operator activated="true" class="performance_classification" compatibility="8.0.001" expanded="true" height="82" name="Performance" width="90" x="246" y="34">
<list key="class_weights"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="performance 1"/>
<portSpacing port="sink_test set results" spacing="0"/>
<portSpacing port="sink_performance 1" spacing="0"/>
<portSpacing port="sink_performance 2" spacing="0"/>
</process>
<operator activated="true" class="recall" compatibility="8.0.001" expanded="true" height="68" name="Recall" width="90" x="447" y="136">
<connect from_op="Retrieve Golf" from_port="output" to_op="Cross Validation" to_port="example set"/>
<connect from_op="Cross Validation" from_port="model" to_port="result 3"/>
<connect from_op="Cross Validation" from_port="example set" to_port="result 2"/>
<connect from_op="Cross Validation" from_port="performance 1" to_port="result 1"/>
<connect from_op="Recall" from_port="result" to_port="result 4"/>
<portSpacing port="sink_result 5" spacing="0"/>
</process>
</process>
In both cases, as expected, the two DT models are strictly the same. Why the attributes
weights are not equals ?
NB : In case of split validation, I retrieve the attribute weights of case 1.
Thanks you for your feedback,
Lionel
