Hi Experts,
I‘m experimenting in text mining and analysis. I’ve created a neighborhood co-occurence from one text and try to analysis and compare it with a larger corpus.
My Example Set look like:
Row No. | Document | Word1 | Word2 | n
1 aaa bbb 2
1 bbb ddd 3
1 aaa bbb 4
2 aaa ccc 3
2 aaa bbb 4
2 ccc aaa 3
This is my process:
<?xml version="1.0" encoding="UTF-8"?><process version="8.0.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.0.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="8.0.001" expanded="true" height="68" name="Retrieve 17-12-21-Spon_10" width="90" x="45" y="34">
<parameter key="repository_entry" value="../data/17-12-21-Spon_10"/>
<operator activated="true" class="text:process_document_from_data" compatibility="7.5.000" expanded="true" height="82" name="Process Documents from Data Spon" width="90" x="179" y="34">
<parameter key="vector_creation" value="Term Frequency"/>
<parameter key="add_meta_information" value="false"/>
<parameter key="keep_text" value="true"/>
<parameter key="prune_method" value="by ranking"/>
<parameter key="prune_below_absolute" value="10"/>
<parameter key="prune_above_absolute" value="3000"/>
<parameter key="data_management" value="memory-optimized"/>
<parameter key="select_attributes_and_weights" value="true"/>
<list key="specify_weights">
<parameter key="link" value="1.0"/>
</list>
<operator activated="true" class="web:extract_html_text_content" compatibility="7.3.000" expanded="true" height="68" name="Extract Content" width="90" x="45" y="34">
<parameter key="minimum_text_block_length" value="2"/>
<operator activated="true" class="text:tokenize" compatibility="7.5.000" expanded="true" height="68" name="Tokenize Token" width="90" x="179" y="34">
<parameter key="mode" value="linguistic tokens"/>
<parameter key="language" value="German"/>
<operator activated="true" class="text:filter_tokens_by_content" compatibility="7.5.000" expanded="true" height="68" name="Filter Tokens a-zA-Z" width="90" x="313" y="34">
<parameter key="condition" value="matches"/>
<parameter key="regular_expression" value="[a-zA-Z]+"/>
<operator activated="true" class="text:transform_cases" compatibility="7.5.000" expanded="true" height="68" name="Transform Cases" width="90" x="447" y="34"/>
<connect from_port="document" to_op="Extract Content" to_port="document"/>
<connect from_op="Extract Content" from_port="document" to_op="Tokenize Token" to_port="document"/>
<connect from_op="Tokenize Token" from_port="document" to_op="Filter Tokens a-zA-Z" to_port="document"/>
<connect from_op="Filter Tokens a-zA-Z" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="subprocess" compatibility="8.0.001" expanded="true" height="103" name="Splitting" width="90" x="313" y="34">
<operator activated="true" class="select_attributes" compatibility="8.0.001" expanded="true" height="82" name="Select Attributes" width="90" x="45" y="34">
<parameter key="attributes" value="text"/>
<operator activated="true" class="generate_id" compatibility="8.0.001" expanded="true" height="82" name="Generate ID" width="90" x="45" y="136"/>
<operator activated="true" class="rename" compatibility="8.0.001" expanded="true" height="82" name="Rename ID" width="90" x="45" y="238">
<parameter key="old_name" value="id"/>
<parameter key="new_name" value="Document"/>
<list key="rename_additional_attributes"/>
<operator activated="true" class="set_role" compatibility="8.0.001" expanded="true" height="82" name="Set Role" width="90" x="45" y="340">
<parameter key="attribute_name" value="text"/>
<operator activated="true" class="rename" compatibility="8.0.001" expanded="true" height="82" name="Rename" width="90" x="179" y="34">
<parameter key="old_name" value="text"/>
<parameter key="new_name" value="word"/>
<operator activated="true" class="split" compatibility="8.0.001" expanded="true" height="82" name="Split" width="90" x="179" y="136">
<parameter key="attributes" value="word"/>
<parameter key="split_pattern" value="\s+"/>
<operator activated="true" class="transpose" compatibility="8.0.001" expanded="true" height="82" name="Splitting Output" width="90" x="313" y="34"/>
<connect from_port="in 1" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Rename ID" to_port="example set input"/>
<connect from_op="Rename ID" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Rename" to_port="example set input"/>
<connect from_op="Rename" from_port="example set output" to_op="Split" to_port="example set input"/>
<connect from_op="Split" from_port="example set output" to_op="Splitting Output" to_port="example set input"/>
<connect from_op="Split" from_port="original" to_port="out 2"/>
<connect from_op="Splitting Output" from_port="example set output" to_port="out 1"/>
<portSpacing port="source_in 2" spacing="0"/>
<portSpacing port="sink_out 3" spacing="0"/>
</process>
<operator activated="true" class="subprocess" compatibility="8.0.001" expanded="true" height="82" name="Neighborhood co-ocurrence" width="90" x="447" y="34">
<operator activated="true" class="r_scripting:execute_r" compatibility="7.2.000" expanded="true" height="82" name="Generate Bigrams" width="90" x="45" y="34">
<parameter key="script" value="rm_main = function(data) { 	library(dplyr) 	library(tidytext) 	spon_bigrams <- data %>% 	 unnest_tokens(bigram, word, token = "ngrams", n = 2) 	print(spon_bigrams) return(list(spon_bigrams)) } "/>
<operator activated="true" class="r_scripting:execute_r" compatibility="7.2.000" expanded="true" height="82" name="Seperate Bigrams" width="90" x="179" y="34">
<parameter key="script" value="rm_main = function(data) { 	library(dplyr) 	library(tidytext) 	library(tidyr) 	library(tokenizers) 	devided_bigrams <-data %>% 	 separate(bigram, c("word1", "word2"), sep = " ") 	 print(devided_bigrams) 	#bigrams_filtered <- devided_bigrams %>% 	# filter(!word1 %in% stopwords("de")) %>% 	# filter(!word2 %in% stopwords("de")) return(list(devided_bigrams)) } "/>
<operator activated="true" class="r_scripting:execute_r" compatibility="7.2.000" expanded="true" height="82" name="Count Bigrams per Page" width="90" x="313" y="34">
<parameter key="script" value="rm_main = function(data) { 	library(dplyr) 	library(tidytext) 	library(tidyr) 	count_bigrams_per_page <- data %>% 	 count(Document, word1, word2) 	print(count_bigrams_per_page) 	counted_bigrams_per_page <- data.frame(count_bigrams_per_page) return(counted_bigrams_per_page) } "/>
<connect from_port="in 1" to_op="Generate Bigrams" to_port="input 1"/>
<connect from_op="Generate Bigrams" from_port="output 1" to_op="Seperate Bigrams" to_port="input 1"/>
<connect from_op="Seperate Bigrams" from_port="output 1" to_op="Count Bigrams per Page" to_port="input 1"/>
<connect from_op="Count Bigrams per Page" from_port="output 1" to_port="out 1"/>
</process>
<operator activated="true" class="set_role" compatibility="8.0.001" expanded="true" height="82" name="Set Role (2)" width="90" x="581" y="34">
<parameter key="attribute_name" value="Document"/>
<operator activated="true" class="nominal_to_numerical" compatibility="8.0.001" expanded="true" height="103" name="Nominal to Numerical" width="90" x="715" y="34">
<list key="comparison_groups"/>
<operator activated="true" class="support_vector_machine" compatibility="8.0.001" expanded="true" height="124" name="SVM" width="90" x="849" y="34"/>
<operator activated="true" class="subprocess" compatibility="8.0.001" expanded="true" height="82" name="Crawler Spon" width="90" x="45" y="187">
<operator activated="true" class="web:crawl_web_modern" compatibility="7.3.000" expanded="true" height="68" name="Crawl Web" width="90" x="112" y="34">
<parameter key="url" value="http://www.spiegel.de"/>
<list key="crawling_rules">
<parameter key="store_with_matching_url" value=".+www.spiegel.+"/>
<parameter key="follow_link_with_matching_url" value=".+spiegel.+|.+de.+"/>
</list>
<parameter key="max_crawl_depth" value="10"/>
<parameter key="retrieve_as_html" value="true"/>
<parameter key="add_content_as_attribute" value="true"/>
<parameter key="max_pages" value="10"/>
<parameter key="delay" value="100"/>
<parameter key="max_concurrent_connections" value="200"/>
<parameter key="max_connections_per_host" value="100"/>
<parameter key="user_agent" value="Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:55.0) Gecko/20100101 Firefox/55.0"/>
<operator activated="true" class="web:retrieve_webpages" compatibility="7.3.000" expanded="true" height="68" name="Get Pages" width="90" x="246" y="34">
<parameter key="link_attribute" value="Link"/>
<parameter key="page_attribute" value="link"/>
<parameter key="random_user_agent" value="true"/>
<connect from_op="Crawl Web" from_port="example set" to_op="Get Pages" to_port="Example Set"/>
<connect from_op="Get Pages" from_port="Example Set" to_port="out 1"/>
</process>
<operator activated="true" class="text:process_document_from_data" compatibility="7.5.000" expanded="true" height="82" name="Process Documents from Data Spon (2)" width="90" x="179" y="187">
</list>
<operator activated="true" class="web:extract_html_text_content" compatibility="7.3.000" expanded="true" height="68" name="Extract Content (2)" width="90" x="45" y="34">
<operator activated="true" class="text:tokenize" compatibility="7.5.000" expanded="true" height="68" name="Tokenize Token (2)" width="90" x="179" y="34">
<operator activated="true" class="text:filter_tokens_by_content" compatibility="7.5.000" expanded="true" height="68" name="Filter Tokens a-zA-Z (2)" width="90" x="313" y="34">
<operator activated="true" class="text:transform_cases" compatibility="7.5.000" expanded="true" height="68" name="Transform Cases (2)" width="90" x="447" y="34"/>
<connect from_port="document" to_op="Extract Content (2)" to_port="document"/>
<connect from_op="Extract Content (2)" from_port="document" to_op="Tokenize Token (2)" to_port="document"/>
<connect from_op="Tokenize Token (2)" from_port="document" to_op="Filter Tokens a-zA-Z (2)" to_port="document"/>
<connect from_op="Filter Tokens a-zA-Z (2)" from_port="document" to_op="Transform Cases (2)" to_port="document"/>
<connect from_op="Transform Cases (2)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="subprocess" compatibility="8.0.001" expanded="true" height="103" name="Splitting (2)" width="90" x="313" y="187">
<operator activated="true" class="select_attributes" compatibility="8.0.001" expanded="true" height="82" name="Select Attributes (2)" width="90" x="45" y="34">
<operator activated="true" class="generate_id" compatibility="8.0.001" expanded="true" height="82" name="Generate ID (2)" width="90" x="45" y="136"/>
<operator activated="true" class="rename" compatibility="8.0.001" expanded="true" height="82" name="Rename ID (2)" width="90" x="45" y="238">
<operator activated="true" class="set_role" compatibility="8.0.001" expanded="true" height="82" name="Set Role (3)" width="90" x="45" y="340">
<operator activated="true" class="rename" compatibility="8.0.001" expanded="true" height="82" name="Rename (2)" width="90" x="179" y="34">
<operator activated="true" class="split" compatibility="8.0.001" expanded="true" height="82" name="Split (2)" width="90" x="179" y="136">
<operator activated="true" class="transpose" compatibility="8.0.001" expanded="true" height="82" name="Splitting Output (2)" width="90" x="313" y="34"/>
<connect from_port="in 1" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Generate ID (2)" to_port="example set input"/>
<connect from_op="Generate ID (2)" from_port="example set output" to_op="Rename ID (2)" to_port="example set input"/>
<connect from_op="Rename ID (2)" from_port="example set output" to_op="Set Role (3)" to_port="example set input"/>
<connect from_op="Set Role (3)" from_port="example set output" to_op="Rename (2)" to_port="example set input"/>
<connect from_op="Rename (2)" from_port="example set output" to_op="Split (2)" to_port="example set input"/>
<connect from_op="Split (2)" from_port="example set output" to_op="Splitting Output (2)" to_port="example set input"/>
<connect from_op="Split (2)" from_port="original" to_port="out 2"/>
<connect from_op="Splitting Output (2)" from_port="example set output" to_port="out 1"/>
</process>
<operator activated="true" class="subprocess" compatibility="8.0.001" expanded="true" height="82" name="Neighborhood co-ocurrence (2)" width="90" x="447" y="187">
<operator activated="true" class="r_scripting:execute_r" compatibility="7.2.000" expanded="true" height="82" name="Generate Bigrams (2)" width="90" x="45" y="34">
<operator activated="true" class="r_scripting:execute_r" compatibility="7.2.000" expanded="true" height="82" name="Seperate Bigrams (2)" width="90" x="179" y="34">
<operator activated="true" class="r_scripting:execute_r" compatibility="7.2.000" expanded="true" height="82" name="Count Bigrams per Page (2)" width="90" x="313" y="34">
<connect from_port="in 1" to_op="Generate Bigrams (2)" to_port="input 1"/>
<connect from_op="Generate Bigrams (2)" from_port="output 1" to_op="Seperate Bigrams (2)" to_port="input 1"/>
<connect from_op="Seperate Bigrams (2)" from_port="output 1" to_op="Count Bigrams per Page (2)" to_port="input 1"/>
<connect from_op="Count Bigrams per Page (2)" from_port="output 1" to_port="out 1"/>
</process>
<operator activated="true" class="set_role" compatibility="8.0.001" expanded="true" height="82" name="Set Role (4)" width="90" x="581" y="187">
<operator activated="true" class="nominal_to_numerical" compatibility="8.0.001" expanded="true" height="103" name="Nominal to Numerical (2)" width="90" x="715" y="187">
<operator activated="true" class="apply_model" compatibility="8.0.001" expanded="true" height="82" name="Apply Model" width="90" x="983" y="136">
<connect from_op="Retrieve 17-12-21-Spon_10" from_port="output" to_op="Process Documents from Data Spon" to_port="example set"/>
<connect from_op="Process Documents from Data Spon" from_port="example set" to_op="Splitting" to_port="in 1"/>
<connect from_op="Splitting" from_port="out 2" to_op="Neighborhood co-ocurrence" to_port="in 1"/>
<connect from_op="Neighborhood co-ocurrence" from_port="out 1" to_op="Set Role (2)" to_port="example set input"/>
<connect from_op="Set Role (2)" from_port="example set output" to_op="Nominal to Numerical" to_port="example set input"/>
<connect from_op="Nominal to Numerical" from_port="example set output" to_op="SVM" to_port="training set"/>
<connect from_op="SVM" from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_op="Crawler Spon" from_port="out 1" to_op="Process Documents from Data Spon (2)" to_port="example set"/>
<connect from_op="Process Documents from Data Spon (2)" from_port="example set" to_op="Splitting (2)" to_port="in 1"/>
<connect from_op="Splitting (2)" from_port="out 2" to_op="Neighborhood co-ocurrence (2)" to_port="in 1"/>
<connect from_op="Neighborhood co-ocurrence (2)" from_port="out 1" to_op="Set Role (4)" to_port="example set input"/>
<connect from_op="Set Role (4)" from_port="example set output" to_op="Nominal to Numerical (2)" to_port="example set input"/>
<connect from_op="Nominal to Numerical (2)" from_port="example set output" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/>
</process>
</process>
I’m out of ideas how to compare and analyse them.
Please, has someone an idea how I can do this?
Regards
Tobias
