hello @fangirl96 - welcome to the community. I think I understand and believe you just need to adjust your regex. Can you give some examples and the process you're using (see instructions "Read Before Posting" on the right).
Scott
This is the full xml of my process.
<?xml version="1.0" encoding="UTF-8"?><process version="7.5.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.5.003" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="7.5.003" expanded="true" height="68" name="Read Excel" width="90" x="45" y="34"> <parameter key="excel_file" value="C:\Users\ace\Desktop\Airasia1 total.xlsx"/> <parameter key="imported_cell_range" value="A1:A14"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="Text.true.text.attribute"/> </list> </operator> <operator activated="true" class="read_excel" compatibility="7.5.003" expanded="true" height="68" name="Read Excel (3)" width="90" x="45" y="136"> <parameter key="excel_file" value="C:\Users\ace\Dropbox\Thesis V3.0\Thesis 2 - data gathering (testing 3) with additional\Negative\neg_airasia.xlsx"/> <parameter key="imported_cell_range" value="A1:A184"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="Text.true.text.attribute"/> </list> </operator> <operator activated="true" class="read_excel" compatibility="7.5.003" expanded="true" height="68" name="Read Excel (4)" width="90" x="45" y="238"> <parameter key="excel_file" value="C:\Users\ace\Dropbox\Thesis V3.0\Thesis 2 - data gathering (testing 3) with additional\Negative\neg_cebupac.xlsx"/> <parameter key="imported_cell_range" value="A1:A53"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="Text.true.text.attribute"/> </list> </operator> <operator activated="true" class="append" compatibility="7.5.003" expanded="true" height="124" name="Append" width="90" x="179" y="136"/> <operator activated="true" class="text:data_to_documents" compatibility="7.5.000" expanded="true" height="68" name="Data to Documents" width="90" x="313" y="34"> <list key="specify_weights"/> </operator> <operator activated="true" class="text:process_documents" compatibility="7.5.000" expanded="true" height="103" name="Process Documents" width="90" x="447" y="34"> <process expanded="true"> <operator activated="true" breakpoints="before,after" class="text:replace_tokens" compatibility="7.5.000" expanded="true" height="68" name="Replace Tokens" width="90" x="112" y="34"> <list key="replace_dictionary"> <parameter key="@[a-zA-Z]*" value=" "/> <parameter key="#[a-zA-Z0-9]*" value=" "/> </list> </operator> <operator activated="true" class="text:transform_cases" compatibility="7.5.000" expanded="true" height="68" name="Transform Cases" width="90" x="112" y="136"/> <operator activated="true" class="text:tokenize" compatibility="7.5.000" expanded="true" height="68" name="Tokenize" width="90" x="112" y="238"> <parameter key="expression" value="\[\d*\][^\[\]]*"/> </operator> <operator activated="true" class="text:stem_porter" compatibility="7.5.000" expanded="true" height="68" name="Stem (Porter)" width="90" x="246" y="136"/> <operator activated="true" class="text:filter_stopwords_dictionary" compatibility="7.5.000" expanded="true" height="82" name="Filter Stopwords (Dictionary)" width="90" x="246" y="238"> <parameter key="file" value="C:\Users\ace\Dropbox\Thesis V3.0\THESIS 4\airasia.txt"/> </operator> <operator activated="true" class="text:generate_n_grams_terms" compatibility="7.5.000" expanded="true" height="68" name="Generate n-Grams (Terms)" width="90" x="380" y="238"/> <connect from_port="document" to_op="Replace Tokens" to_port="document"/> <connect from_op="Replace Tokens" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Stem (Porter)" to_port="document"/> <connect from_op="Stem (Porter)" from_port="document" to_op="Filter Stopwords (Dictionary)" to_port="document"/> <connect from_op="Filter Stopwords (Dictionary)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/> <connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Read Excel" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Read Excel (3)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Read Excel (4)" from_port="output" to_op="Append" to_port="example set 3"/> <connect from_op="Append" from_port="merged set" to_op="Data to Documents" to_port="example set"/> <connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Process Documents" from_port="example set" to_port="result 1"/> <connect from_op="Process Documents" from_port="word list" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
The links are not removed but the hashtags were removed.
PS. The links included in my data is starting with https
thank you @fangirl96 - can you share one of those excel sheets as well?
@fangirl96 take a look at my tutorial process here: http://www.neuralmarkettrends.com/blog/entry/use-rapidminer-discover-twitter-content
I extract hashtags and drop https: to a generic word called 'link'
