I am facing an issue of ordering the cloumns after pivoting. The index attribute is Week no. Now when I pivot the data, the columns go like : Week-1, week-10, Week-11......Week-2, Week-20,.....Week-3, Week-30,....
Whereas I need it to be : Week-1, Week-2, Week-3.....
<?xml version="1.0" encoding="UTF-8"?><process version="7.5.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.5.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_macro" compatibility="7.5.001" expanded="true" height="82" name="Generate Macro" width="90" x="112" y="85">
<parameter key="end_date" value="date_str_custom(date_add(date_now(), -1, DATE_UNIT_DAY), "yyyy-MM-dd")"/>
</list>
<operator activated="true" class="subprocess" compatibility="7.5.001" expanded="true" height="82" name="Subprocess" width="90" x="246" y="85">
<operator activated="true" class="jdbc_connectors:read_database" compatibility="7.5.001" expanded="true" height="68" name="Read Database (2)" width="90" x="45" y="34">
<parameter key="connection" value="DVDH_zDMaqsud"/>
<parameter key="query" value="SELECT `Candidate` FROM `Candidate_Name_List` -- where Candidate like '%cliff%'"/>
<enumeration key="parameters"/>
<operator activated="true" class="r_scripting:execute_r" compatibility="7.2.000" expanded="true" height="82" name="Execute R" width="90" x="179" y="34">
<parameter key="script" value="# rm_main is a mandatory function, # the number of arguments has to be the number of input ports (can be none) rm_main = function(input_data) { library(gtrendsR) for (i in 1:nrow(input_data)) { 		trend <- data.frame(gtrends(input_data$Candidate[i], time = "2017-01-01 %{end_date}")$interest_over_time) 		if ( i == 1) { 			all_trends <- trend 		} else { 			all_trends <- rbind(all_trends, trend) 		} } all_trends$date <- as.character(all_trends$date) return(all_trends) } "/>
<operator activated="true" class="select_attributes" compatibility="7.5.001" expanded="true" height="82" name="Select Attributes (2)" width="90" x="313" y="34">
<parameter key="attributes" value="date|keyword|hits"/>
<operator activated="true" class="nominal_to_date" compatibility="7.5.001" expanded="true" height="82" name="Nominal to Date (2)" width="90" x="447" y="34">
<parameter key="attribute_name" value="date"/>
<parameter key="date_format" value="yyyy-MM-dd"/>
<connect from_op="Read Database (2)" from_port="output" to_op="Execute R" to_port="input 1"/>
<connect from_op="Execute R" from_port="output 1" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Nominal to Date (2)" to_port="example set input"/>
<connect from_op="Nominal to Date (2)" from_port="example set output" to_port="out 1"/>
<portSpacing port="source_in 2" spacing="0"/>
</process>
<operator activated="true" class="date_to_numerical" compatibility="7.5.001" expanded="true" height="82" name="Date to Numerical" width="90" x="380" y="85">
<parameter key="time_unit" value="week"/>
<parameter key="keep_old_attribute" value="true"/>
<operator activated="true" class="sort" compatibility="7.5.001" expanded="true" height="82" name="Sort" width="90" x="514" y="85">
<parameter key="attribute_name" value="date_week"/>
<operator activated="true" class="rename" compatibility="7.5.001" expanded="true" height="82" name="Rename" width="90" x="648" y="85">
<parameter key="old_name" value="keyword"/>
<parameter key="new_name" value="Candidate"/>
<list key="rename_additional_attributes"/>
<operator activated="true" class="generate_attributes" compatibility="7.5.001" expanded="true" height="82" name="Generate Attributes (3)" width="90" x="782" y="85">
<parameter key="Scaled_Value" value="((hits)*100)"/>
</list>
<operator activated="true" class="select_attributes" compatibility="7.5.001" expanded="true" height="82" name="Select Attributes" width="90" x="916" y="85">
<parameter key="attributes" value="Candidate|date_week|hits|Scaled_Value"/>
<operator activated="true" class="aggregate" compatibility="7.5.001" expanded="true" height="82" name="Aggregate" width="90" x="1050" y="85">
<parameter key="Scaled_Value" value="sum"/>
</list>
<parameter key="group_by_attributes" value="date_week|Candidate"/>
<operator activated="true" class="pivot" compatibility="7.5.001" expanded="true" height="82" name="Pivot" width="90" x="1184" y="85">
<parameter key="group_attribute" value="Candidate"/>
<parameter key="index_attribute" value="date_week"/>
<operator activated="true" class="rename_by_replacing" compatibility="7.5.001" expanded="true" height="82" name="Rename by Replacing" width="90" x="1318" y="85">
<parameter key="replace_what" value="(sum\(Scaled_Value\)_)"/>
<parameter key="replace_by" value="Week-"/>
<connect from_port="input 1" to_op="Generate Macro" to_port="through 1"/>
<connect from_op="Generate Macro" from_port="through 1" to_op="Subprocess" to_port="in 1"/>
<connect from_op="Subprocess" from_port="out 1" to_op="Date to Numerical" to_port="example set input"/>
<connect from_op="Date to Numerical" from_port="example set output" to_op="Sort" to_port="example set input"/>
<connect from_op="Sort" from_port="example set output" to_op="Rename" to_port="example set input"/>
<connect from_op="Rename" from_port="example set output" to_op="Generate Attributes (3)" to_port="example set input"/>
<connect from_op="Generate Attributes (3)" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Aggregate" to_port="example set input"/>
<connect from_op="Aggregate" from_port="example set output" to_op="Pivot" to_port="example set input"/>
<connect from_op="Pivot" from_port="example set output" to_op="Rename by Replacing" to_port="example set input"/>
<connect from_op="Rename by Replacing" from_port="example set output" to_port="result 1"/>
</process>
</process>
It seems it is sorting out based on first digit of the week no.
Please advise.
