Hello Everybody
I Want to make a hybrid recommender system like below link: https://ashokharnal.wordpress.com/2014/04/28/recommender-system-using-rapidminer/
I really Go Confused And I really need Help.question 1: what are the outputs of MF and Item K-nn?question 2: how Combiner combines MF and Item K-nn outputs?question 3: what kind of algorithm is used in MF like SVD or ….?
I really Need your help very much.
I've never used this extension but if you were to right click on the operator in question and select Operator Info, it should tell you want all the inputs and outputs are.
the Info doesn't give enough help
I'm afraid I'm not the right guy to help you with this extension, have you tried searching through the community? There's lots of threads about the extension.
