Hi RM team, I'm trying to call Facebook graph API using Enrich Data by Webservice operator which I'm using inside the Loop Values operator that outputs a collection of documents. Input data is a csv with a bunch of facebook business page usernames. Basically, as far as I understand, the Loop Values operator is supposed to grab each username and return me some facebook content for each handle, but -
- it is only doing that partially
- each document in the collection from Loop Values should only contain data for one username however it contains all the usernames and only one row of data per user.
Attached:
- RM process
- Input excel
- JSON output from facebook API from an API testing platform.
Any help will be greatly appreciated as I'm kind of on a deadline for this. Thank you.
PROCESS
<?xml version="1.0" encoding="UTF-8"?><process version="7.5.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.5.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_excel" compatibility="7.5.001" expanded="true" height="68" name="Read Excel" width="90" x="112" y="34">
<parameter key="excel_file" value="C:\Users\Pari\Documents\BDC\Socials\Facebook Scrapper\Test\TestHandles.xlsx"/>
<parameter key="imported_cell_range" value="A1:A5"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="0" value="Username.true.polynominal.attribute"/>
</list>
<operator activated="true" class="concurrency:loop_values" compatibility="7.5.001" expanded="true" height="82" name="Loop Values" width="90" x="313" y="34">
<parameter key="attribute" value="Username"/>
<operator activated="true" class="web:enrich_data_by_webservice" compatibility="7.3.000" expanded="true" height="68" name="Enrich Data by Webservice (2)" width="90" x="313" y="34">
<parameter key="query_type" value="JsonPath"/>
<list key="string_machting_queries"/>
<list key="regular_expression_queries"/>
<list key="regular_region_queries"/>
<list key="xpath_queries"/>
<list key="namespaces"/>
<list key="index_queries"/>
<list key="jsonpath_queries">
<parameter key="message" value="$..message"/>
<parameter key="post id" value="$..id"/>
</list>
<parameter key="url" value="https://graph.facebook.com/v2.10/&lt;%Username%&gt;/posts?access_token=1745625495738593|w_a8sajfHCYsCHNZOTDr5H1r-wY"/>
<list key="request_properties"/>
<parameter key="encoding" value="UTF-8"/>
<connect from_port="input 1" to_op="Enrich Data by Webservice (2)" to_port="Example Set"/>
<connect from_op="Enrich Data by Webservice (2)" from_port="ExampleSet" to_port="output 1"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<connect from_op="Read Excel" from_port="output" to_op="Loop Values" to_port="input 1"/>
<connect from_op="Loop Values" from_port="output 1" to_port="result 1"/>
</process>
</process>
JSON Output
"data": [
"created_time": "2017-10-31T12:01:32+0000",
"message": "Click to read news on #Tableau latest conference.\n#BigData #Tech",
"id": "1563861787269208_1910035019318548"
"created_time": "2017-10-30T22:02:02+0000",
"message": "\"South Australia is about to get “Big Doctor”, cloud-based artificial intelligence that analyses our health and intervenes when it spots something amiss.\"-Brad Crouch",
"id": "1563861787269208_1909800592675324"
"created_time": "2017-10-30T21:21:00+0000",
"message": "Why you should welcome Artificial Intelligence with open arms",
"id": "1563861787269208_1909790786009638"
"created_time": "2017-10-30T12:00:59+0000",
"message": "\"AI will put bankers out of work? Some people think these advances will boost productivity, enabling industries to actually increase the number of jobs\"",
"id": "1563861787269208_1909600706028646"
"created_time": "2017-10-27T12:01:38+0000",
"message": "What's Elon Musks stance on Artificial Intelligence?",
"id": "1563861787269208_1908177749504275"
"paging": {
"cursors": {
"before": "Q2c4U1pXNTBYM0YxWlhKNVgzTjBiM0o1WDJsa0R5TXhOVFl6T0RZAeE56ZAzNNalk1TWpBNE9qazFPVEE1TURrME56STJOelkzTlRZAeU9ROE1ZAWEJwWDNOMGIzSjVYMmxrRHlFeE5UWXpPRFl4TnpnM01qWTVNakE0WHpFNU1UQXdNelV3TVRrek1UZAzFORGdQQkhScGJXVUdXZAmhtSEFFPQZDZD",
"after": "Q2c4U1pXNTBYM0YxWlhKNVgzTjBiM0o1WDJsa0R5UXhOVFl6T0RZAeE56ZAzNNalk1TWpBNE9pMHlORGs0TURBMk9UZA3pOVEEyTkRJMU9EUVBER0ZA3YVY5emRHOXllVjlwWkE4aE1UVTJNemcyTVRjNE56STJPVEl3T0Y4eE9UQTRNVGMzTnpRNU5UQTBNamMxRHdSMGFXMWxCbG56SUNJQgZDZD"
"next": "https://graph.facebook.com/v2.10/1563861787269208/posts?pretty=1&limit=5&after=Q2c4U1pXNTBYM0YxWlhKNVgzTjBiM0o1WDJsa0R5UXhOVFl6T0RZAeE56ZAzNNalk1TWpBNE9pMHlORGs0TURBMk9UZA3pOVEEyTkRJMU9EUVBER0ZA3YVY5emRHOXllVjlwWkE4aE1UVTJNemcyTVRjNE56STJPVEl3T0Y4eE9UQTRNVGMzTnpRNU5UQTBNamMxRHdSMGFXMWxCbG56SUNJQgZDZD"
