Hey,
I'm using the extension "dictionary based sentiment analysis" and have got a problem with some meta data output at the end. Everything works out fine, but i cannot see the token number. What i wanted to do: Screening text, scoring each text, output is negative/ positive and the number of uncovered tokens - so in order to be able to use the "number of uncovered tokens" i want to know the number of total tokens i have in my text. I'm using the "Extract token number" but it won't display at the end.
Thanks for help
<?xml version="1.0" encoding="UTF-8"?><process version="7.6.001">
<operator activated="true" class="text:tokenize" compatibility="7.5.000" expanded="true" height="68" name="Tokenize" width="90" x="246" y="34">
<parameter key="mode" value="non letters"/>
<parameter key="characters" value=".:"/>
<parameter key="language" value="English"/>
<parameter key="max_token_length" value="3"/>
</process>
<operator activated="true" class="text:filter_stopwords_german" compatibility="7.5.000" expanded="true" height="68" name="Filter Stopwords (German)" width="90" x="447" y="34">
<parameter key="stop_word_list" value="Standard"/>
</process>
<operator activated="true" class="text:filter_by_length" compatibility="7.5.000" expanded="true" height="68" name="Filter Tokens (by Length)" width="90" x="179" y="187">
<parameter key="min_chars" value="4"/>
<parameter key="max_chars" value="40"/>
</process>
<operator activated="true" class="text:transform_cases" compatibility="7.5.000" expanded="true" height="68" name="Transform Cases (2)" width="90" x="313" y="187">
<parameter key="transform_to" value="lower case"/>
</process>
<operator activated="true" class="text:extract_token_number" compatibility="7.5.000" expanded="true" height="68" name="Extract Token Number" width="90" x="514" y="187">
<parameter key="metadata_key" value="token_number"/>
<parameter key="condition" value="all"/>
<parameter key="case_sensitive" value="false"/>
<parameter key="invert_condition" value="false"/>
</process>
