Altair RISE
Nominate Yourself Now!
Twitter Access Token error
User: "hawthorn_33"
New Altair Community Member
Updated by Jocelyn
I'm trying to access Twitter to do sentiment analysis using Aylien Extension on Rapidminer Studio latest version.
When I try to set up the twitter access token, I get an error message - The token is in the Following error.
Twitter API Access Token has incorrect format
Can anyone assist in resolving this error.
Thanks
1 - 3 of 31
    User: "hawthorn_33"
    OP
    I resolved this problem.
    The error message (Twitter API Access Token has incorrect format) is ambigious as it's not the Twitter access token format that caused the problem.
    I renewed the Rapidminer "OAuth" code when setting up Twitter connection in Rapidiminer and this fixed the problem.
    User: "sohaib6678"
    Hi
    I want to extract data from twitter but when i run process of getting tweets of user... Than it generate error of twitter API error...
    What should i do to resolve this problem????
    User: "sgenzer"
    most likely you are hitting the rate limits. Did you see the documentation on this?
