I'm setting up my first instance (trial) of RapidMiner Server, and have done so by loading the RapidMiner Server image for Virtual Machines on the Microsoft Azure Marketplace. This seems to come with all the network settings preconfigured.
I can now connect to the VM through SSH, but I'm stuck on the guide provided (https://docs.rapidminer.com/server/installation/cloud_images.html) at the bottom, final numbered list on point 1, which reads "Using a browser connect to the virtual machine's port 8080. (e.g. http://public.ip:8080)".
I've tried connecting to the server (replacing with my Public IP for the VM), but get the error "ERR_CONNECTION_REFUSED".
I'm thinking the service might not be running on the VM, so opened and SSH connection to the VM (following this guide), locating the file 'standalone.sh' and trying to execute that. Returns error "command not found".
Not quite sure what I'm missing - how exactly do I get access to the web instance of RapidMiner server, or ensure that the service is running on the VM?
Thanks for any feedback!
P.
