Hello All,
I am trying to integrate RM in My Java Application, I am using a educational version and created this particular code after integrating the jar.
package rm;
import com.rapidminer.*;
import com.rapidminer.Process;
import com.rapidminer.operator.Operator;
import com.rapidminer.operator.nio.ExcelExampleSource;
import com.rapidminer.operator.OperatorDescription;
import java.io.File;
import java.io.FileReader;
import java.io.IOException;
public class CSVDataLoader {
public static void rmCSVLoader(){
try {
RapidMiner.setExecutionMode(RapidMiner.ExecutionMode.COMMAND_LINE);
RapidMiner.init();
Process process = new Process(new File("D:\\TUM\\Master Thesis\\RapidMiner\\NewProcess.rpm"));
Operator op = process.getOperator("Read Excel");
op.setParameter(ExcelExampleSource.PARAMETER_EXCEL_FILE, "D:\\TUM\\Master Thesis\\DataSets\\Task.xls");
process.run();
} catch (Exception ex) {
ex.printStackTrace();
However when I run it I get the below exception, can somebody please help me.
[warn] com.rapidminer - Could not parse XML settings file: settings.xml. Cause: Attribute key not found.
[warn] com.rapidminer - Cannot create operator description: RapidMiner Core : process
java.lang.NoClassDefFoundError: com/twelvemonkeys/imageio/spi/ImageReaderSpiBase
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:763)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:467)
at java.net.URLClassLoader.access$100(URLClassLoader.java:73)
at java.net.URLClassLoader$1.run(URLClassLoader.java:368)
at java.net.URLClassLoader$1.run(URLClassLoader.java:362)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:361)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
Caused by: java.lang.ClassNotFoundException: com.twelvemonkeys.imageio.spi.ImageReaderSpiBase
at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
[warn] com.rapidminer - Cannot create operator description: RapidMiner Core : dummy
java.lang.NoClassDefFoundError: Could not initialize class com.rapidminer.operator.OperatorDescription
at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:354)
at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:346)
at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:320)
at com.rapidminer.tools.OperatorService.registerOperators(OperatorService.java:267)
at com.rapidminer.tools.OperatorService.registerOperators(OperatorService.java:239)
at com.rapidminer.tools.OperatorService.init(OperatorService.java:133)
at com.rapidminer.RapidMiner.init(RapidMiner.java:638)
at com.rapidminer.RapidMiner.init(RapidMiner.java:573)
[warn] com.rapidminer - Cannot create operator description: RapidMiner Core : hierarchical_classification
Uncaught error from thread [application-akka.actor.default-dispatcher-2] shutting down JVM since 'akka.jvm-exit-on-fatal-error' is enabled for ActorSystem[application]
java.lang.NoClassDefFoundError: Could not initialize class com.rapidminer.gui.tools.SwingTools
at com.rapidminer.tools.GroupTree.loadIcons(GroupTree.java:270)
at com.rapidminer.tools.GroupTree.setIconName(GroupTree.java:217)
at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:340)
at rm.CSVDataLoader.rmCSVLoader(CSVDataLoader.java:17)
[warn] com.rapidminer - Cannot create operator description: RapidMiner Core : read_aml
at controllers.HomeController.index(HomeController.java:17)
at router.Routes$$anonfun$routes$1$$anonfun$applyOrElse$1$$anonfun$apply$1.apply(Routes.scala:359)
at play.core.routing.HandlerInvokerFactory$$anon$4.resultCall(HandlerInvoker.scala:157)
at play.core.routing.HandlerInvokerFactory$$anon$4.resultCall(HandlerInvoker.scala:156)
at play.core.routing.HandlerInvokerFactory$JavaActionInvokerFactory$$anon$14$$anon$3$$anon$1.invocation(HandlerInvoker.scala:136)
at play.core.j.JavaAction$$anon$1.call(JavaAction.scala:73)
at play.http.HttpRequestHandler$1.call(HttpRequestHandler.java:54)
at play.core.j.JavaAction$$anonfun$7.apply(JavaAction.scala:108)
at scala.concurrent.impl.Future$PromiseCompletingRunnable.liftedTree1$1(Future.scala:24)
at scala.concurrent.impl.Future$PromiseCompletingRunnable.run(Future.scala:24)
at play.core.j.HttpExecutionContext$$anon$2.run(HttpExecutionContext.scala:56)
at play.api.libs.iteratee.Execution$trampoline$.execute(Execution.scala:70)
at play.core.j.HttpExecutionContext.execute(HttpExecutionContext.scala:48)
at scala.concurrent.impl.Future$.apply(Future.scala:31)
at scala.concurrent.Future$.apply(Future.scala:492)
at play.core.j.JavaAction.apply(JavaAction.scala:108)
at play.api.mvc.Action$$anonfun$apply$2$$anonfun$apply$5$$anonfun$apply$6.apply(Action.scala:112)
at play.utils.Threads$.withContextClassLoader(Threads.scala:21)
at play.api.mvc.Action$$anonfun$apply$2$$anonfun$apply$5.apply(Action.scala:111)
at play.api.mvc.Action$$anonfun$apply$2$$anonfun$apply$5.apply(Action.scala:110)
at scala.Option.map(Option.scala:146)
at play.api.mvc.Action$$anonfun$apply$2.apply(Action.scala:110)
at play.api.mvc.Action$$anonfun$apply$2.apply(Action.scala:103)
at scala.concurrent.Future$$anonfun$flatMap$1.apply(Future.scala:251)
at scala.concurrent.Future$$anonfun$flatMap$1.apply(Future.scala:249)
at scala.concurrent.impl.CallbackRunnable.run(Promise.scala:32)
at akka.dispatch.BatchingExecutor$AbstractBatch.processBatch(BatchingExecutor.scala:55)
at akka.dispatch.BatchingExecutor$BlockableBatch$$anonfun$run$1.apply$mcV$sp(BatchingExecutor.scala:91)
at akka.dispatch.BatchingExecutor$BlockableBatch$$anonfun$run$1.apply(BatchingExecutor.scala:91)
at scala.concurrent.BlockContext$.withBlockContext(BlockContext.scala:72)
at akka.dispatch.BatchingExecutor$BlockableBatch.run(BatchingExecutor.scala:90)
at akka.dispatch.TaskInvocation.run(AbstractDispatcher.scala:39)
at akka.dispatch.ForkJoinExecutorConfigurator$AkkaForkJoinTask.exec(AbstractDispatcher.scala:409)
at scala.concurrent.forkjoin.ForkJoinTask.doExec(ForkJoinTask.java:260)
at scala.concurrent.forkjoin.ForkJoinPool$WorkQueue.runTask(ForkJoinPool.java:1339)
at scala.concurrent.forkjoin.ForkJoinPool.runWorker(ForkJoinPool.java:1979)
at scala.concurrent.forkjoin.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:107)
[warn] com.rapidminer - Cannot create operator description: RapidMiner Core : write_aml
[warn] com.rapidminer - Cannot create operator description: RapidMiner Core : clustermodel_2_exampleset
[warn] com.rapidminer - Cannot create operator description: RapidMiner Core : decision_tree
[warn] com.rapidminer - Cannot create operator description: RapidMiner Core : random_forest
[warn] com.rapidminer - Cannot create operator description: RapidMiner Core : x_prediction
[warn] com.rapidminer - Cannot create operator description: RapidMiner Core : x_validation
[warn] com.rapidminer - Cannot create operator description: RapidMiner Core : batch_x_validation
[warn] com.rapidminer - Cannot create operator description: RapidMiner Core : retrieve
[warn] com.rapidminer - Cannot create operator description: RapidMiner Core : store
[warn] com.rapidminer - Cannot create operator description: RapidMiner Core : rename_repository_entry
[warn] com.rapidminer - Cannot create operator description: RapidMiner Core : copy_repository_entry
[warn] com.rapidminer - Cannot create operator description: RapidMiner Core : move_repository_entry
[warn] com.rapidminer - Cannot create operator description: RapidMiner Core : delete_repository_entry
