To execute multiple sub processes
arjun
arjun New Altair Community Member
Need help in using switch case without a break so that it uses a right case for execution in Rapidminer
switch (n)
case constant1:
// code to be executed if n is equal to constant1;
break;
case constant2:
// code to be executed if n is equal to constant2;
break;
default:
// code to be executed if n doesn't match any constant
  • jczogalla_edu
    jczogalla_edu New Altair Community Member
    Hi arjun,
    you can use the "Select Subprocess" operator to model each subprocess you need. In the parameter "select which" you can use a macro that you have to create before this operator to select the apropriate subprocess.
    Cheers
    Jan
  • Telcontar120
    Telcontar120 New Altair Community Member
    If you have only two conditions then you can also use the related "Branch" subprocess operator.
