Hi All,
I am trying to use the trim operator to remove a space at the start of my attribute values
But it doesn't seem to be working, I am using v7.5
<?xml version="1.0" encoding="UTF-8"?><process version="7.5.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.5.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="7.5.001" expanded="true" height="68" name="Retrieve CountryAndGPName" width="90" x="246" y="85">
<parameter key="repository_entry" value="../Data/CountryAndGPName"/>
<operator activated="true" breakpoints="before,after" class="trim" compatibility="7.5.001" expanded="true" height="82" name="Trim" width="90" x="447" y="85">
<parameter key="attribute" value="Country"/>
<connect from_op="Retrieve CountryAndGPName" from_port="output" to_op="Trim" to_port="example set input"/>
<connect from_op="Trim" from_port="example set output" to_port="result 1"/>
</process>
</process>
