Hi
I am attempting to extract the id from a JSON string, the below process pulls the entire field required but for some reason it is not breaking the data out into the various columns. What am I missing to pull out the filed "._id"?
As a side note for some reason the JSON is also sending the id field as incremented, so in other word the id's come in sucessing with labels of [0]._id, [1000]._id, [1001]._id. I am not sure if this is having an impact on reading the data in?
<?xml version="1.0" encoding="UTF-8"?><process version="7.5.003">
<operator activated="true" class="productivity:execute_program" compatibility="7.5.003" expanded="true" height="103" name="Execute Program (2)" width="90" x="45" y="187">
<parameter key="command" value="./imp_id.sh"/>
<parameter key="log_stdout" value="true"/>
<parameter key="log_stderr" value="true"/>
<parameter key="working_directory" value="/import_id"/>
<list key="env_variables"/>
</process>
<operator activated="true" class="text:read_document" compatibility="7.5.000" expanded="true" height="68" name="Read Document (2)" width="90" x="179" y="187">
<parameter key="extract_text_only" value="false"/>
<parameter key="use_file_extension_as_type" value="true"/>
<parameter key="content_type" value="txt"/>
</process>
<operator activated="true" class="text:json_to_data" compatibility="7.5.000" expanded="true" height="82" name="JSON To Data" width="90" x="313" y="187">
<parameter key="ignore_arrays" value="false"/>
<parameter key="limit_attributes" value="false"/>
<parameter key="skip_invalid_documents" value="false"/>
</process>
<operator activated="true" class="text:data_to_documents" compatibility="7.5.000" expanded="true" height="68" name="Data to Documents" width="90" x="447" y="187">
<parameter key="select_attributes_and_weights" value="true"/>
<list key="specify_weights">
<parameter key="id" value="1.0"/>
</list>
</process>
<operator activated="true" class="text:combine_documents" compatibility="7.5.000" expanded="true" height="82" name="Combine Documents" width="90" x="581" y="187"/>
</process>
<operator activated="true" class="text:write_document" compatibility="7.5.000" expanded="true" height="82" name="Write Document" width="90" x="715" y="187">
<parameter key="file" value="/test.csv.*"/>
<parameter key="overwrite" value="true"/>
</process>
