Simple question:
What's wrong with this Xpath ?
Now a a little more on information:
I am trying to add information to already available data. Therefore the 'Enrich Data from Web Service' seemed the proper tool.
But I can't get the data I am looking for.
As I found out so far, the Xpath does not work as expected. (This might have to do with my understanding of Xpath ;-) )
Therefore I created a test, which is attached below.
This contains 4 slightly different test cases:
- test_1..3
- test_4..6
- head_1..4
- html
My question.
Why are only some cases delivering data and others not? Especially those where there are elements directly addressed.
Any solutions or hints are welcome.
<?xml version="1.0" encoding="UTF-8"?><process version="7.6.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.6.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="operator_toolbox:create_exampleset_from_doc" compatibility="0.5.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="112" y="85">
<parameter key="Column Separator" value=","/>
<parameter key="Input Csv" value="a 1"/>
<operator activated="true" class="web:enrich_data_by_webservice" compatibility="7.3.000" expanded="true" height="68" name="Enrich Data by Webservice" width="90" x="380" y="85">
<parameter key="query_type" value="XPath"/>
<list key="string_machting_queries"/>
<parameter key="attribute_type" value="Nominal"/>
<list key="regular_expression_queries"/>
<list key="regular_region_queries"/>
<list key="xpath_queries">
<parameter key="test_1" value="//*[@id=&quot;main-container"]//*[@class=&quot;result-content"]//*[@class=&quot;address"]"/>
<parameter key="test_2" value="//*[@id=&quot;main-container"]//*[@class=&quot;result-content"]/div"/>
<parameter key="test_3" value="//*[@id=&quot;main-container"]//*[@class=&quot;result-content"]/div[1]"/>
<parameter key="test_4" value="//*[@id=&quot;main-container"]//*[@class=&quot;result-content"]//*[@itemprop=&quot;url"]"/>
<parameter key="test_5" value="//*[@id=&quot;main-container"]//*[@class=&quot;result-content"]/a"/>
<parameter key="test_6" value="//*[@id=&quot;main-container"]//*[@class=&quot;result-content"]/a[1]"/>
<parameter key="head_1" value="//html"/>
<parameter key="head_2" value="//head"/>
<parameter key="head_3" value="//*/head"/>
<parameter key="head_4" value="//*"/>
<parameter key="html" value="html"/>
</list>
<list key="namespaces"/>
<parameter key="ignore_CDATA" value="true"/>
<parameter key="assume_html" value="true"/>
<list key="index_queries"/>
<list key="jsonpath_queries"/>
<parameter key="request_method" value="GET"/>
<parameter key="url" value="http://www.firmenabc.at/result.aspx?what=haniger+benesch+versicherungs+makler+gmbh&where=&exact=false&inTitleOnly=false&l=&si=0&iid=&sid=-1&did=&cc="/>
<parameter key="delay" value="500"/>
<list key="request_properties"/>
<parameter key="encoding" value="UTF-8"/>
<description align="center" color="transparent" colored="false" width="126">Get the data from FirmenABC</description>
<connect from_op="Create ExampleSet" from_port="output" to_op="Enrich Data by Webservice" to_port="Example Set"/>
<connect from_op="Enrich Data by Webservice" from_port="ExampleSet" to_port="result 1"/>
</process>
</process>
