Hello altogether,
due to the application of the K-Means-Operator I had to change the nominal attributes to numerical. The format I am confronted with now is similar to:
attribute1 = xxx, attribute 1= yyy, attribute 2= zzz, attribute 2 = www
Cluster 1 1 0 0 1
Cluster 2 0 1 0 1
Cluster 1 1 0 1 0
Is there another way to get the attributes back into one column each? Instead of the binary form.
Thank you
Philipp
