Filtering with a looped parameter
User: "edinsda2"
New Altair Community Member
Updated by Jocelyn
Hi All,
I have a data set with dates ranging from the beginning to the end of 2016. I am creating a forecasting model and I want to iterate through the data set multiple times, the first time removing the last 6 months, the second time removing the last 5 months, then removing the last 4 months etc.
I am currently trying to so this using a loop parameters operation and trying to adjust the filter, however I can either not get the syntax right or need a different approach.
Could someone please tell me the exact options to select in the loop parameters tool or a better method
Thank you in advance
1 - 1 of 11
    User: "MartinLiebig"
    Accepted Answer
    Dear Edindsa,
    i would propose to do this with a standard Loop operator. It gives you a macro (e.g. process variable) with the current iteration number. We can use this to generate ourselves a macro with the filter value and use it in the filter. The expressions we use for this can be very sophisticated.
    An example is attached.
    Best,
    Martin
    <?xml version="1.0" encoding="UTF-8"?><process version="7.5.003">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="7.5.003" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="generate_data" compatibility="7.5.003" expanded="true" height="68" name="Generate Data" width="90" x="45" y="34"/>
    <operator activated="true" class="extract_macro" compatibility="7.5.003" expanded="true" height="68" name="Extract Macro" width="90" x="246" y="34">
    <parameter key="macro" value="numberOfExamples"/>
    <list key="additional_macros"/>
    <operator activated="true" class="concurrency:loop" compatibility="7.5.003" expanded="true" height="82" name="Loop" width="90" x="514" y="34">
    <operator activated="true" class="generate_macro" compatibility="7.5.003" expanded="true" height="82" name="Generate Macro (2)" width="90" x="179" y="34">
    <parameter key="filterValue" value="eval(%{iteration})"/>
    </list>
    <description align="center" color="transparent" colored="false" width="126">We can do more complex things here</description>
    <operator activated="true" class="filter_examples" compatibility="7.5.003" expanded="true" height="103" name="Filter Examples (2)" width="90" x="447" y="34">
    <list key="filters_list">
    <parameter key="filters_entry_key" value="att1.gt.%{filterValue}"/>
    </list>
    <operator activated="true" class="h2o:generalized_linear_model" compatibility="7.5.000" expanded="true" height="103" name="Generalized Linear Model (2)" width="90" x="648" y="34">
    <list key="beta_constraints"/>
    <list key="expert_parameters"/>
    <connect from_port="input 1" to_op="Generate Macro (2)" to_port="through 1"/>
    <connect from_op="Generate Macro (2)" from_port="through 1" to_op="Filter Examples (2)" to_port="example set input"/>
    <connect from_op="Filter Examples (2)" from_port="example set output" to_op="Generalized Linear Model (2)" to_port="training set"/>
    <connect from_op="Generalized Linear Model (2)" from_port="model" to_port="output 1"/>
    <portSpacing port="sink_output 1" spacing="0"/>
    <portSpacing port="sink_output 2" spacing="0"/>
    </process>
    <operator activated="false" class="loop_parameters" compatibility="7.5.003" expanded="true" height="82" name="Loop Parameters" width="90" x="514" y="289">
    <list key="parameters">
    <parameter key="Filter Example Range.first_example" value="[1.0;50;3;linear]"/>
    </list>
    <operator activated="true" class="generate_macro" compatibility="7.5.003" expanded="true" height="82" name="Generate Macro" width="90" x="45" y="34">
    <list key="function_descriptions"/>
    <operator activated="true" class="filter_examples" compatibility="7.5.003" expanded="true" height="103" name="Filter Examples" width="90" x="447" y="34">
    <parameter key="filters_entry_key" value="att1.gt.1"/>
    </list>
    <operator activated="true" class="h2o:generalized_linear_model" compatibility="7.5.000" expanded="true" height="103" name="Generalized Linear Model" width="90" x="782" y="34">
    <connect from_port="input 1" to_op="Generate Macro" to_port="through 1"/>
    <connect from_op="Generate Macro" from_port="through 1" to_op="Filter Examples" to_port="example set input"/>
    <connect from_op="Filter Examples" from_port="example set output" to_op="Generalized Linear Model" to_port="training set"/>
    <connect from_op="Generalized Linear Model" from_port="model" to_port="result 1"/>
    <portSpacing port="sink_performance" spacing="0"/>
    </process>
    <connect from_op="Generate Data" from_port="output" to_op="Extract Macro" to_port="example set"/>
    <connect from_op="Extract Macro" from_port="example set" to_op="Loop" to_port="input 1"/>
    <connect from_op="Loop" from_port="output 1" to_port="result 1"/>
    </process>
    </process>
