I drag a Read Database operator in the process view and then try to edit the parameter, but the parameter can not be edited as showing (btw, I already added a database connection in manage database connections):
Not sure how to solve the problem?
I think your panels got messed up, it looks like they're not docked correctly. Can you go to View > Restore Default View
