Hello
I have the stress - strain values at discrete data points from uni- tensile test.
Could you please tell me
1. Which Material for this situation?
2.How too include that in Hypermesh while defining material properties ?
Thank you!
1. please refer to Reference Guide>Starter Input>Materials in Radioss help. Search with keyword 'tabulated' for material models allowing stress-strain input. Choose the material model that will allow you to specify materials properties relevant to your simulation (strain rate, viscoelasticity, hyperelasticity,...)
2. stress-strain values are referenced in material models by curves (XYPlots>Curve Editor)
Hello I have the stress - strain values at discrete data points from uni- tensile test. <?xml version="1.0" encoding="UTF-8"?> Could you please tell me 1. Which Material for this situation? 2.How too include that in Hypermesh while defining material properties ? Thank you!
You can use the MATS1 and TABLED1 combination and run a non-linear analysis in OptiStruct
or
use LAW36 in RADIOSS (assuming the data is for isotropic material)
You can use the MATS1 and TABLED1 combination and run a non-linear analysis in OptiStruct or use LAW36 in RADIOSS (assuming the data is for isotropic material)
Hi.
I tried to use Mat LAW36, as I know, I created a stress and strain curve and put it in fct_ID_E but It said YOUNG�S MODULUS SCALE FUNCTION SHOULD DECREASE WITH PLASTIC STRAIN
ERROR ID : 975 ** ERROR IN MATERIAL FUNCTION DEFINITION
How can I deal with this problem?
This error is regarding the material function. This law models an isotropic elastoplastic material using user-defined functions for the work-hardening portion of the stress-strain curve (for example, plastic strain vs. stress) for different strain rates. The first point of yield stress functions (plastic strain vs stress) should have a plastic strain value of zero.
There are other material laws (for example law 38) that allow stress-strain to be prescribed over the whole strain range. What kind of material is it? Judging from the stress-strain presented it is not metal so material law 36 might not be the best fit.
@IvanThank you very much.
In my model I have an equivalent material with the stress and strain as the picture, this curve seems like hyper elastic material. I used Mat LAW69 and it works .I am still wondering about this kind of material because the strain is not so large (only 15% maximum)
